?12 bolt one ton axle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Apr 9, 2001.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I found an ad with a set of one ton axles for sale, so I call and he says it is not a Dana 60, but is not a Dana44. He said it is bigger than a d44 but not as big as a d60 and has a 12 bolt cover. I did some research and found that even d60's only have 10 bolts on the cover. So what is this thing?
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    hmm thats interresting iv never heard of such a thing maybe its a older dana something or other sure someone has seen one on here so jsut wait some will spil beans on it [​IMG]
    Bandit
    (Your right i dont understand the jeep thing)
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Is the dude sure its a Chevy axle? About the only other 1-ton I can think of that MIGHT have 12 bolts would be the Ford (Sterling) 10.25 inch. Its full floating, 8 lug, etc. I just don't know how many bolts it has...maybe thats it. Or maybe that guy doesn't know what the hell he's talking about.
    '73 K5
    Chevy good...Ford bad
  4. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Doesn't sound like a one ton to me.
    12 bolt= heavy half, 3/4 ton
    <A target="_blank" HREF=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </A>
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you are talking about front axles, the only ones ever used since the late 60's that I know of are either the Dana 44 (1/2 and 3/4 ton up to around '77), GM Corp. 10-bolt (1/2 and 3/4 ton from '77 on), and the Dana 60 (1 ton only, '77 on).
    The only GM offered axle with 12-bolts on the cover was the 12-bolt, which was only offered as a rear axle in 1/2 tons. BTW, I've never heard of a 12-bolt being used in a 3/4 ton.....they had either the full-floating or semi-floating 14-bolts.
  6. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I went to see them today. They were 3/4 ton axles. A 10 bolt front and a 14 bolt sf rear. Anyway, I bought the 10 bolt for $125 and a set of smogable Thorleys for $125. The front axle is 8 lug, so I thought it was at least that. He also had a bunch of other stuff that I will list in parts for sale.
    Not FROM the people
