12 bolt pinion seal leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Aug 14, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    My 12 bolt is leaking out where the drive shaft connects to the axle. Is this something hard to replace or is it something that a gear shop shouuld do?
  2. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Fairly easy. Remove Driveshaft, place drain pan under rear output shaft of T-Case. Remove the pinon nut, then remove the pinon yoke. Replace the seal, replace the yoke. Torque nut to specs. Repalce oil in Diff, top off t-case
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    If you don't understand Pinion Bearing Pre-Load, then I highly suggest you find out more about it.
    Good luck
  4. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    An air impact really helps out...when its off check the sealing surface for wear...if you can feel a dip in the surface with your thumbnail replace the yoke or it will leak again!
    Also...you have those rear panels i wanted before the why 3 k5 run?
    AZBlazer
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  5. Impex
    469
    Chandler, AZ
    what panels are they?
  6. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    Bigbad's got it down, I'd also check to make sure the breather on your diff is clear, or you could blow that seal again as soon as you hit the highway. Took me two seals to figure that one out!
    MIDCAN k5 " DIG A HOLE!!!"
  7. K5 NUTT
    1,611
    Must be someone else i met at the Tempe get together...rear panels for the cargo area.
    AZBlazer
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
