12 bolt posi question?
Discussion in 'The Garage' started by 13lazer, Dec 23, 2005.
  1. 13lazer
    13lazer 1/2 ton status
    Dec 30, 2004
    San Pedro, CA
    im swapping my rebuilt 373 ring and pinion into a 2 wheel drive coil spring rear that has a tired 410 setup. when i pulled the pin out the spider gears in the posi moved and i cant get the pin back in. should i just tear it all the way down or is there a trick?
    nevermind, i lined up the spider gears with a c clamp. the diff is in the shop because i dont understand preload or setting up the gears.
