12 bolt posi rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lukerz, Jun 18, 2001.
  1. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    Has anyone ever done a 12-bolt posi rebuild ???
    Lukers
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I have. Ask and we will try to respond.
  3. lukerz
    Apr 13, 2001
    109
    Western Mass
    I am wondering if I should purchsae a 12 bolt posi that needs a rebuild for $50? or just weld my open carrier?
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Depends what's screwed in the the posi rear... just the posi unit? Or does it need all the bearing and a R&P too? Also if it is a stock gov-lok I know I have heard stories of them scattering parts and screwing the whole rearend... then some just don't function anymore. tRusty has the Lincoln Locker (welded spiders) going and seems to like it... maybe give him a PM. I'm sure he'd be glad to help out w/ the LL questions you may have.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  5. Executioner
    Feb 22, 2000
    1,530
    If it is the Eaton Possi, with four springs, buy it and rebuild it with the new carbon fiber clutches, and the 800
    pound pre-load springs. If its a Gov-Lock Eaton Possi, have them pay you 50 to take it off their hands !
    Good luck
    P.S. its gonna be old if its and original Eaton Possi with four springs, Tip have the part/peices magnfulxed before
    you rebuilt it.
  6. lukerz
    Apr 13, 2001
    109
    Western Mass
    Do you have an opinion about a EZ lockers made by tractech? This would be an easy install right? I am cheap and want to set up for better traction.
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  7. Executioner
    Feb 22, 2000
    1,530
    Yes, they(EZ Locker) are weak in my opinion, if you want a bolt-on Locker go with the Lock-Right(Powertrax) locker. Most say they are the same, just name brand.
    Good luck
