12 Bolt Posi swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Mar 13, 2002.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    What all do i need to do when installing a limited slip into my 12 bolt?
  2. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Come on with all of you who are online someones gotta be able to help me.
  3. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Guys I really need help fast.
  4. dyeager535
    26,982
    191
    check out www.ring-pinion.com, maybe give them a call.
    To do it, you'll need the posi carrier (I'd go Eaton if doing an actual posi unit, thats what Randy's will recommend anyways I'm sure) and you'll need a "complete" axle overhaul kit. All the bearings, crush sleeve, marking compound, etc. You can re-use your gears if they aren't shot.
