12 bolt posi
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lukerz, Jun 15, 2001.
  1. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    Hi all,
    Quick question about changing from 5 lug to six lug on a 12 bolt rear. I have a non posi 6 lug and want to convert to posi. Can I just swap axles from my non posi into the posi rear end?
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    as long as the spline count is the same why not just take the posi and put it in your 12bolt? thats what i did to mine
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The axles just swap out. I have a friend that just did the opposit (6lug to 5lug). As long as it is a truck 12bolt you will be fine.
    '71 Blazer CST with alot of rust
  4. lukerz
    Apr 13, 2001
    109
    Western Mass
    Did you have to worry about changing out crush sleeves and all the alignment stuff for the differential?
    Luke
    Th350 Np203 355 CID
    31 X 10.5
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i took it in to a local shop and had it done it cost me like $200 but that also included the posi unit being rebuilt[​IMG]
  6. lukerz
    Apr 13, 2001
    109
    Western Mass
    I might want to do this myself. I am ground up when it comes to this. Anyone ever done a rebuild on a 12 bolt posi?
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
