12 bolt posi ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka73, Sep 17, 2000.
  1. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    Hi guys some of you might remember that I posted about my 12 bolt rearend breaking two teeth one from the pinion and one from the ring well I haven't fixed it cause I was debating on wheter to regear or buy another one and swap them well I bought another one but this time it's a posi unit 12 bolt, my question is what gears would it have if when I turn the wheel one complete time the shaft turns a little over 4 times, the guy I bought it from told me it had 411's but I thought that 411's were only for F*rds and 410 for chevys so wich one do you guys think it is or am I wrong and he's right any info on this question appreciated thanks guys, by the way I bought the rear differential for $175 is that a good price????? the gears do look good.
    check out my new site, thanks Steve!
    http://chaka73.coloradok5.com
  2. slodawg
    slodawg 1/2 ton status
    Apr 30, 2000
    190
    Southern Arkansas
    Iff its a chevy rear it should have the gear ratio stamped in the ring gear. If you cant read or find that count total number of teeth on ring gear then count total number on pinion gear and divide this will give you the ratio. I really dont know about the tire/d-shaft thing. Ive never really got how to do that. 175 is a good price for around here. I paid 150 for a 12 bolt 3.73 without posi.
    <font color=blue>SLODAWG</font color=blue>
    http://www.slodawg.coloradok5.com
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    4.10s, 4.11s, what does it matter if you spun it then counted, a little over 4 times, then yes 4......something. You could A, get the code off the rear, then run it, someone on this site always has a code breakdown. Or do what I would, change the gear oil and while the cover is off count up the ring and pinion teeth, then divide pinion into ring and wala. also check the posi clutches and if you want replace them so you don't have to be hassled down the line........JS its probably 4.11s
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Sounds like you have 4.10's in it.People just call them 4.11 somtimes just like somepeople call Landcruisers or old Nissan Patrols Jeeps.It is just a generic term.Chevy's actually have 4.09's in the front 44's and 4.10's in rear 12 bolts and FF14's.That is a fair price compared to regearing the other one.I blew out the pinion bearing in my 12 bolt last year.I bought a pair of axles(44 front and 12 bolt for $100)with the wrong gears I needed.So i had the new rear axle regeared(4.10's).I put all new gears and bearings in and had it set up a Stage West.It cost me about $600 total but I have an axle that is basicly new.I would tear down the axle and check everything before you put it in and make sure it is all fine.Brady
  5. chaka73
    377
    Southern California
    Hey guys thanks for the answers, I guess I'll do the oil change and count the teeth and come up with the ratio, I'll also going to tear the thing appart and change whatever needs to be changed thanks again.
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I have 12 bolt possi front and rear, oh ya 4.11's front and rear.
    Good day
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I'm sure that I'm not the only one that is skeptical about your "12-bolt front". I know that the factory never came out with a 12-bolt front axle. If you do have one, it's not factory. It's a completely custom axle. It might be a good idea, but they never came with them and I've never heard of one being built. Show us a picture that clearly illustrates a 12-bolt front-end and this skepticism will end. Not trying to start a fight, I just want to see this thing.
    Thanks,
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  8. Brady
    May 6, 2000
    628
    Parachute,Co
    I think your looking at a dana 44 and counting the 12 bolts that hold the dif. cover on then calling it a 12 bolt.Look at the shape of the front then compare it to the rear.The 44's side are straight up and down and the 12 bolts cover is more round.Brady
  9. BUDDY
    Apr 28, 2000
    744
    Midland, TX
    Dana 44's 60's and 70's have 10-bolt covers.
    Buddy
  10. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Hey Now if the "EXECUTIONER" says its a FACT it must be so, he's never wroung and HE NEVER BACKS UP HIS FACTS!!!!! I would love to know were he gets front drive axels, no he would never need one! Its a FRONT 12 BOLT!!
    I understand the jeep thing I drive a BLAZER!!
    Ken
  11. Executioner
    Feb 22, 2000
    1,530
    It's a two of a kind thing, you would not understand !
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Let me guess.....I bet the Executioner has that rare factory option front 12-bolt plus the even rarer factory front posi option. So rare that only 1 was ever produced, right??????
    I definitely want to see a picture of this front 12-bolt so we have some "verifiable facts"..........
  13. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    children, children......
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
