12-bolt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NerdBoy, Mar 18, 2004.
  1. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    A guy that I sold some tires to offered me a 12-bolt off a late-70s 2 wheel drive 1/2 ton.
    1) Will this bolt in place of my 10-bolt, or are there differences between the spring pads or shock mounts?
    2) If it will bolt in, is this a stronger axle than the 10-bolt?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1. It will bolt in, but you will need a conversion u joint as your current axle is a Saginaw and that is a 1310.
    2. It has five lug axles so your wheels and tires will not bolt to it.
    3. You would be wasting your time doing this swap IMO, as the 12 bolt is just as weak as the 10 bolt.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Just stick with the 10 bolt, nothing spectacular with the 12, very similar to the 10.
