12 bolt r&p
Discussion in 'Pacific Region' started by leadfoot067, Aug 19, 2003.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    anybody have a 373 0r 4.10 for a 12 bolt they wanna get rid of??? just need a ring and pinion
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    As soon as I get my a$$ over and pick up the 12b I am buying I will have a matched set of 3.73's to sell... though not just a R&P
  3. leadfoot067
    May 14, 2001
    1,563
    well its for my 2wd dd. si i cant even use the housing or anything..
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You can still use the 4x4 housing /forums/images/graemlins/thumb.gif you would only need to relocate the shock brackets which is fairly easy to do with a grinder and welder. I have been running a 2wd 12 bolt for over a year with my original 6 lug axle shafts and brake parts. Now I am running a 2wd 14FF in its place and the shocks still bolt up but limit droop.
    **edit** Of course what year truck are you putting it in? Topdowns K5 being a first gen would have 40" spring spacing so that will mean you would have to relocate the spring perches as well for any 2wd...
  5. leadfoot067
    May 14, 2001
    1,563
    its a 67 gmc short wide box...
  6. kennyw
    Jun 9, 2002
    13,223
    94
    2wd, '67 GMC should have the 42.5" spring pad spacing. I have a 12 bolt with 3.40 gears not currently in use with 6 lug axleshafts.
    Why not run a D44 rear axle? Isn't that stock in your truck? They are non-C-clip axles which is better in my opinion.
  7. leadfoot067
    May 14, 2001
    1,563
    no its a 12 bolt... i checked when i got it with 355 gears,.the truck i had in high school was a 67 gmc swb also and it had the dana 44 with 3.54 gears in it...dont know if somebody changed it or what /forums/images/graemlins/confused.gif
  8. kennyw
    Jun 9, 2002
    13,223
    94
    It has been changed if it has a 12 bolt in it now. The 73-87 GM 12 bolts have the same spring perch spacing and will bolt in though with the shock mounts relocated.
