12 bolt rear end question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Z3PR, May 17, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The rear end in my 76 Blazer is the factory originnal. It's bone stock, nothings ever been done to it. I just replaced the U-joints in the drive shaft. The 12 bolt has play in it. It clunks like a bad U-joint when I go from reverse to drive and vice-versa. It also has that feel and clunk sound when I give it gas after coasting down hill . How worried should I be ????
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Are you sure it's the 12 bolt making the clunk? Could be slop in the t-case too. Mine kinda does the same thing....Always has. Still does it even with the new 12 bolt...I reset the backlash, preload everything. It's not as bad as before, but it still does it it a bit.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I know there is play in the rear end. Don't know if the clunking is coming from rear end or T-case. Thought it was comming from rear.
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    there is spoesed to be some play in it or it would bind , could also be your t case and trans .
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It sounds like a bad U-joint. I don't notice it all the time, but some times it's pretty loud, and I do feel it.
  6. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    my bet is on the transfer case. i bet the chain is a bit worn!! i had an 86 k5 that did the same thing and i kept pumping money into the rear end and u-joints to no avail.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The chain only drives the front output shaft of the t-case. So a worn chain should not have any effect on the amount of slop in the rear driveline.
