12 bolt ring gear eating through cover!
Discussion in 'The Garage' started by SkulzNBonz, May 12, 2003.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thankfully not mine. Since I know just the smallest amount about how a rear end even works, let alone what locates the ring gear, I will pose my question here. Why would the ring gear start eating through the cover. My best educated guess is that a axle bearing, or race, or whatever holds the ring gear in position is wearing out. Supposedly, this axle was a fresh rebuild with just a few hundred miles on it. Thanks in advance.
    John
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Did the cover get bent into the ring gear? That would be my first guess since the axle has been rebuilt.
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    The caps holding the carrier to the housing might be coming loose. That would be my guess
  4. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks for the reply Neil. Guess I should elaborate, this twelve bolt is on a '65(?) Malibu, w/ a 468 CI Olds under the hood. The car has been under the knife for about two years. Absolutely 0 abuse, this thing is a show & go rod.
    Sorry for the confusion.
    John
  5. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks, I'll check it out.
    John
