12 bolt strength?
Discussion in 'The Garage' started by lochenjons, Jan 31, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    How does my '77 12 bolt compare to good ol' 10b and 14b? Isnt it about the same as a newer 10b? I think that's what I heard
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    its marginally stronger than a 10 bolt, ya know, a 10 bolt can hold up to 31s with 35 psi, but a 12 bolt can hold up to 31s with 31 psi...
  3. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    mine holds up to 36.5s at all psi's.for 12 years.:D
  4. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    I would go with a 14bff...they are a dime a dozen and very strong
  5. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Its pretty comparable in strength to a 10 bolt. It is nowhere near even close to a 14ff. 14ff= 10.5" ring gear, and a full floating design. 12b= 8.875" ring gear, and semi floating. and thats just the basics
    -harrison
  6. boggerless
    May 26, 2003
    22,728
    96
    rocks or mud??mud you can be an asshole and win.:haha: weight is the thing in the mud.rock? i could not tell ya!plus it helps toknow what to do.:laugh:
  7. chris walker
    chris walker Registered Member
    Sep 5, 2005
    42
    Arizona
    12 bolt good for 33 in all conditions sf14 bolt good for 37 in all conditions ff14 good from 33-44 in all conditions
  8. boggerless
    May 26, 2003
    22,728
    96
    i'm in mud mostly so it works good for now.:D
  9. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    This discussion comes up daily. Search a little and you find all kinds of opinions. The popular view is upgrade to a 14bff. Here's another recent discussion Click
    The cost of a 14bff is super cheap. Now add the cost of the 8 lug outers for the front. If you go to a bigger tire to regain the clearance lost by the bigger pumpkin, you will have to swap out the front to a D60. Now big $$$
    There are some bullet proof rigs on this site built right for serious crawling. :bow:
  10. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Yeah I know 14ff is the way to go. This is actaully why I ask because I found one for cheap(ish) but wasnt really planning the swap for later and wondering as to how much success other people have had with the 12b to see how long I could run it with worrying too much about breakage
  11. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    It depends on your driving style, right foot pressure. A lot of guys are running 12 bolts with 33's and 35's without problems. They carry extra shafts "just in case."
    I'm personally staying with 10 front and 12 bolt rear. I'm upgrading shafts and calling it good. Nothing is ever bullet proof. The tallest tire I will run is 35 or 37. I'm in the minority opinion staying stock and throwing a little money into it.
    Anyone else want to chime in???
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1/2 ton axles can be totally servicable in a wheeling truck up to about 37" tires max. 35" is a good size for keeping breakage to a minimum. The AZ guys have learned recently that on a fullsize truck with built 1/2 ton's 37" is about the limit for hard wheeling. I have seen 3 snapped Chromo D44 stubs, 1 twisted shortside D44 inner, several twisted 12 bolt housings & chromo axles, along with other major breakage. Keep in mind that most of these trucks are in the minority of wheelers. They are trucks that are rockcrawled to the fullest extent of there limitations.
    If you are a moderate wheeler and only plan on 35" tires then put a set of chromo shafts in the 12 bolt and wheel it. Chromo rear shafts are not as much money as many think. They will cost you less then a 14bff & will get you on the trails sooner. You should get plenty of use out of it under all but extreme conditions if the diff is in good shape.
    Harley
  13. UPS
    UPS 1/2 ton status
    Aug 2, 2006
    438
    Maine
    I have 35" boggers on my 12 bolt and haven't had any problem running it in the mud, but the 305 doesn't have any power and the 700r4 slips.
    I have a very heavy right foot, but I don't get after it in hard ruts.
    I also haven't had any problems with the 10 bolt front.
    I think it would be a different story if the truck had some power.
    Mike
  14. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I`m only running 33"s, and looking for an axle upgrade out back... How does the 12b compare to the 14bsf? Is the 12b a worthwhile upgrade, with me only running 33s? The only wheeling I do really is mud...
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    A 14bsf is better/stronger then a 12 bolt.
    Harley
  16. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    The 14bsf is a 9.5 inch ring gear, the 12 bolt is a 8.75 inch ring.
    Here is an axle chart with some information.
  17. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I think the SF is the way to go, but I would need it in 6 lug, which I might as well go discs, which would convert it to 6 lug...
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are 6 lug 14bsf axles out there under light duty 3/4 ton Chevy's from 88+. You will have to move the spring perches for them to fit but they are out there & work. A 14bsf is a better choice then a 12 bolt if you can get one & are looking to stay 6lug.
    Harley
  19. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Yep, that's what I'm doing (6 lug 14SF).
  20. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    If your wanting to upgrade go with the 14bsf or 14bff. IMO going from a 10b to a 12b is a waste of time and money.
