12 bolt truck vs. 12 bolt car
Discussion in 'The Garage' started by GRAYTEXK5, Apr 5, 2004.
  1. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    are truck 12 bolt rear ends the same as car 12 bolts? My blazer has a 12 bolt rear, and I have a chevelle with a 10 bolt. I'm wondering if, when I put a 14bolt in the blazer, can I use the 12 in the chevelle? I know I would have to have the spring and shock mounts changed, and have it narrowed...but do the axleshafts interchange, since I would need 5 lugs? thanks for any help you can give me.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    They arn't the same...the car 12bolts are stronger. That doesn't mean you couldn't swap it in...you just might need to mess with it some to make it all work out /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  3. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    That suprises me that car 12's would be stronger. You'd think the companies would want to put the stronger part in the vehicle that needs it. Even though the Chevelle would put out a lot of torque through that axle...
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its the car 12b pinion stems that are bigger than the trucks' 12b pinion stems
