12 Bolt Upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FastBanshee, Aug 23, 2002.
  1. FastBanshee
    FastBanshee Registered Member
    Aug 16, 2002
    17
    San Diego, CA
    How much should I except to pay to upgrde my GM 12 bolt. I wana put in new axles, 4.56 gears, Limited slip. How much should I except to pay a shop here in San Diego to do this for me?
  2. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    just have a look at this $$$$$
    pick ur part and add it up!!then add between 100-300 to have it put in.
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I did mine in southern Cal about 3 1/2 years ago. Did mine with a Posi, 4:56, and full rebuild kit (including Bearings). Just over $1200.00.
  4. FastBanshee
    Aug 16, 2002
    17
    San Diego, CA
    The 12 bolt is a 30 spline axle right?
  5. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Depending on where you go here are a few ideas on mail order parts. Expect to pay around $565 for a Detroit Locker (full case locker - the best) for 4.56 gear ratio, $170 for gears, $100 for full rebuild kit with bearings and seals. Try to Contact Tim Swanson (forgot his username). He sold me a brand new set of gears and install kit for under $200 shipped. With a Detroit, aftermarket axleshafts and a properly setup gearset, you can run up to a 38" tire. I have done this for over a year without problems. I have the Warn Full Floater which relieves bearing side loads plus provides a stronger axle shaft. Being Full Floater makes it nice if you have problems enternally, you can still flat tow the vehicle. I know you will hear this from many people - Why not install a 14 bolt? Have the hubs drilled for 6 lug. The Detroit is cheaper - Gears will be a little higher. But, you will not need to upgrade with a full floater kit or aftermarket axles. I run my 12 bolt because I bought all the parts cheap enough. I plan to go either 1 ton or 2.5 ton in the next year so my stuff will be up for sale. Its not a problem with the 12 bolt design - its just a Ring Gear strength issue with me. I have broken a diff and a gearset in the past - so keep that in mind.
    Good luck.
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Depending on timeframe, you might be better off looking for a beat up 3/4 ton with 4.56's installed. One just sold here locally for $500 (the guy stripped the axles and sold the frame/cab for $200). You would have to pony up for 8 lug rims/tires but those can be had at a decent price if you look. This way you would have upgraded axles (may be lucky and score a rear with a locker already installed), rims/tires for about the same (depending on what the availablility is in your area) or a slightly more. Again you don't have to go this route, but it is something to look into.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Depends on if you are upgrading the front or rear axle. /forums/images/icons/wink.gif /forums/images/icons/smirk.gif /forums/images/icons/grin.gif
  8. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Keep your eyes open too!! I came across someone that just wanted his wreck taken away. He had installed some 4:11s in it within 6 months. I took it home pulled out mine installed these and I'm ready to go! I was VERY lucky.
    /forums/images/icons/grin.gif Marty---
  9. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    [/ QUOTE ] /forums/images/icons/grin.gif
  10. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Hey I saw that !
  11. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    "Front or rear?"
    What truck had a 12 bolt front exactly?
    /forums/images/icons/confused.gif
  12. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    welp here we go again...THERE ISNT A PRODUCTION 12 BOLT front!!!!
    NITRO
  13. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    why not go to a 14 bolt? it would not need anything new if your lucky. just put in around $350 for a detriot.
  14. 83PJW
    Aug 18, 2002
    160
    leavenworth, ks
    oh i forgot.... they also came stock with 4.11s pretty close to a 4.56
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hey Executioner!!! Where ya been buddy? /forums/images/icons/confused.gif /forums/images/icons/grin.gif
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    "Front or rear?"
    Go back and look at the smilie faces I left after the sentence. /forums/images/icons/wink.gif /forums/images/icons/grin.gif
  17. FastBanshee
    Aug 16, 2002
    17
    San Diego, CA
    I don't wana go to a 14B FF because I have 6 lug rims. My truck is going to be a daily driver and be in the dirt when im in the desert.
