12 bolt vs 10 bolt
Discussion in 'The Garage' started by jacked_86chevyk10, Jun 24, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    how much stronger is a 12 bolt than a 10 bolt rear? im building a pavement pounder (i know...but i also have a k5 mud bucket!) and i have some 15" weld racing that i really like, how much tire will my 10 bolt honestly stand on the road? ive searched through past threads and no one really has an answer for jus dailydriving on 1/2 gear...what would be the best idea for this setup? or possibly running a 14 bolt SF (the 6 lug type, but the only problem is i dont know where to get those SF 14 bolt...what kinda truck/van did they come in?) im tired of drivin the mudbucket around bc clean is good sometimes....thanks fellas
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    35's is recommended largest size on 1/2 ton gear. I happily drive to work and wheel with a 12 bolt , and I am stubborn so I will use it until its dead . A lot of people would say upgrade to a stronger axle , but if it won't really get wheeled hard , spend the money on some emissions legal performance enhancers .
    I have seen 8 lug 14bsf in Suburbans 3/4 ton and 6 lug in later model Tahoes, Suburbans , pickups . /forums/images/graemlins/k5.gif
  3. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I'd be realy leary of trying to go bigger that 35's IMO.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The 12 bolt is only stonger than the 10 by hair, not worth a swap IMO.
    Hell, if your just driving on the streets you could slap some 40's on those babies!
  5. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    *Hi-Jack On* About what year are the 14bsf found in those vehicles. That's what I want for my rig. *Hi-Jack Off*
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    In all honesty, a 14 bolt FF with 8 to 6 lug adaptor ( will line rear wheels up with front ) isn't a bad idea. Plus a 14 bolt FF is cheap.
  7. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I have seen them in the '88 and newer light duty 3/4 trucks. They may be in others as well. If you get one from an '88 or newer it will need new spring perches welded on.
  8. ugly_blazer
    Apr 12, 2004
    1,214
    I ran a 10 bolt front and a 12 bolt rear w/gov-lok and 17/40-15 monster mudders on the street and often in the mud and never had any problems. I say go for it.
    A 14 bolt FF is cheap, but it will likely not match his front gear ratio. If he needs to swap a front gear ratio it makes the 14 FF not seem as cheap anymore, especially after buying adapters. I would think that for street use and mild wheelin' that he might be better to strengthen the 10 bolt if breakage becomes an issue. /forums/images/graemlins/dunno.gif If a different gear ratio is desired then it would be cheap to buy a matched set of 3/4 tons /forums/images/graemlins/thumb.gif
  9. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    depends on how much power your pushin, and how you are drivin it... If your doin burnouts then id keep em around 35" or so, if your just cruisin, 40's would be fine, prolly even larger.. Many factors weigh in on this..... I ran 38's on half ton gear for a long time, broke one rear axle, and that was just cuz i was being stupid.
  10. jacked_86chevyk10
    Feb 4, 2004
    42
    SNELLVILLE, GA
    thanks fella, theres a guy on cardomain who ran 44 tsl with 1/2 gear and he had one of those 14bsf...sweettruck though!!! but thats the way ill prolly go..thanks for the comments and recomendations!!! I JUS GOTTA SAY MAN I LOVE CK5!!!!!
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    For a truck that will mainly be street cruising the biggest issue will be the horsepower and how hard it is being used. From my experience a 10 or 12-bolt will not hold up very well behind a mild to medium small block, 35" or bigger tires, AND hard street use (burn-outs, heavy towing, etc....). I'm not saying it will always break the first time you spin the tires, but it will eventually break if abused.
    The 14SF would be a nice compromise, though I'm not sure why so many people think they are hard to find. The 8-lug 14SF was used in most 3/4 ton GM trucks from the early-80's on. The 6-lug version was introduced with the body style change (IFS trucks) in '88 and used in the light duty 3/4 tons and a few 1/2 tons, though I don't believe it's a bolt-in on a pre-'88 truck. It should be fairly easy to either re-drill the shafts and drums from 8-lug to 6-lug, or just swap in the 6-lug stuff onto an 8-lug axle.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Isn't he also talking about going to larger tires ??? In my mind that also means regearing so ya don't burn up a automadic transmission. Yeap, the matched 3/4 tons is the rought I'd go.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In my opinion the 12 bolt is not any stronger than the 10 bolt. Some parts of it are even weaker. Ring and pinion is bigger, yes...but the rest of it is just as worthless as a 10 bolt.
    Knowing what I know now I would never spend a dime on anything less than a D44/10 bolt front with 8 lugs and 14 full floater rear. I see no point in going with anything smaller than that when 3/4 ton axles are a dime a dozen.
