12 bolt vs. 14bsf
Discussion in 'The Garage' started by Ben B., Aug 23, 2006.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    My badass new '78 K10 has a 12 bolt rear, would it be worth upgrading to a 14bsf in the future or is the strength near the same? My 35's will be on the K10 soon...I'm pretty sure the 12 bolt will hold up though.
    Opinions.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    The 14sf is a fair amount stronger than your 12 bolt. If I were you, I would run the 12 bolt 'til you break it then replace it with a 14sf.
  3. dyeager535
    26,975
    If you want to continue running your 6 lug wheels, start looking for the SF now, as 6 lug 14SF's (especially the gearing you want, whatever it is) aren't real easy to find. They are out there, but you may spend some time looking before you find the right one.
    They aren't infinitely stronger than a 12 bolt, but for parts failure, you hear very little about the 14SF.
  4. Ben B.
    Sep 1, 2005
    352
    Central PA
    That's always the plan. lol
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A good set of axleshafts and a 1350 yoke are a great way to semi-bulletproff the 12 bolt with 35 inch tires . A disc brake setup will hold the axles in if you break one .
    Myself , I just wheel mine and carry shafts . Its cheaper for me . I will probably end up breaking something I don't carry :thumb:
  6. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    I wheel a 12 bolt and carry shafts. 35s are the max so I hear but so far the only thing I broke was a 2 week old ring and pinion. Richmond warrantied it due to the hardening not being proper.
    gabe
  7. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    bit off topic sry if im high jacking but does a 14bsf come in a 5 lug?
  8. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I wheel a 12bolt. I broke it last year at Blazer Bash, stripped teeth off the ring gear. The ring and pinion were 37 years old, and the guys that fixed it thought that the gears were setup wrong when the Detroit was installed. I was still able to limp the truck back to Moab, about 15 miles.
    I'm still running the 12bolt with new 4.56 gears. No more breakage. I say run the 12bolt until it breaks.
  9. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    They came 5 lug in 454ss trucks, but you can get aftermarket shafts for fairly cheap. Ive also seen some 2wd work truck that had a 14sf and 5 lug.
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Wow...!
    No 14bFF advice.... :dunno:
    Ok... I'll do it...... GET A FULL FLOATER...!
    :D
    Marv
  11. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    x2
    Usually run-it-till-it-breaks is good advice to avoid spending too much $$$ during the build process.... but ff14b axles are so damn cheap that it doesn't really make sense to skimp. You see them for $100-200 all the time... and if you can't afford that, you can't afford to go wheeling anyway. ;)
    j
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Whats funny is I have spent 2 or 3 times a 14bff buying up all the shafts I can for 10b fronts and 12 bolt rears . I haven't broken one yet ( knocks on wood ) I just want to corner the market . Someday all the 14bff will be under every last K5-K30 , every jeep and Bronco , and all that will be left is 12 bolts and 10 bolts ..... and I will be the only one with the shafts :pimp:
  13. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Well.... just to set the record straight..... I was joking.
    I'm still running that 1/2 ton crap myself!:haha: Someday I'll get in the big leages!
    Marv
  14. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    Let's not forget approx $200 for the 8-lug wheels, presumably 15"ers to fit the tires he has now. Around here it's another $100 for 8-lug outers from the u-pull-it. You'll have to cough up more money for spring perches if it's a 1-ton 14bff. And that damn conversion joint is almost $40.
  15. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    There is a big difference between a 12 bolt and a 14 bolt SF, if you put the carriers side by side you will see what I mean. I didn't feel like buying new wheels or converting my front to 8 lugs so I run a 14 B SF with 6 lugs, I don't plan on running tires bigger than 37's so I think it should be OK.
  16. bajaviking
    Apr 10, 2002
    752
    Baja
    You forgot about the always entertaining e-brake issue, I don't know about you guys but I like having an e-brake when I have to park my truck on a hill in the middle of the trail.
  17. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    True that!
  18. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    The difference between 14sf and 10b. Im sure the 12b one isnt too much bigger.
  19. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    doesn't anyone make a 8-to-6 lug spacer/conversion? save the $ from having to buy new wheels etc. I dunno, for me, not breaking my rear end is worth more than $100. I rarely get to go wheeling and if I **** up a trip with something as silly as a rear axle shaft I'd be highly annoyed. lol!
    j
  20. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I meant to post this in my last post. Ooops
