12 bolt welded spider gears?
Discussion in 'The Garage' started by 69k5blaz, Mar 28, 2003.
  1. 69k5blaz
    69k5blaz Registered Member
    Jan 20, 2003
    35
    Lafayette, IN
    I have a 12 bolt rear on my 69 blaz and i want to weld the spider gears. I havent heard of any one doing this is the unit strong enough?
  2. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I run with a guy down here with a welded 12 bolt and 38.5s in his Blazer and it’s held together for quite a while. Keep in mind the trails we run are mostly mud so without knowing what you point you’re truck at or how you treat the skinny pedal, I can’t say what kind of luck you can expect.
    I still have the 12 bolt in my Jimmy and don’t have the confidence in it's strength of it to weld it up. The way I drive, I don’t think it make it through the first run.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I welded up the spiders in the 12 bolt in my 82. I ran a trailride the next weekend and they held up great. I was trying to climb a waterfall ledge and I had the blazer bouncing off the ground... After a while it ended up like this:
    It lasted all weekend and til now they have been fine!!!
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    :steals post: Great Pic! /forums/images/graemlins/thumb.gif
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    A friend of mine just called me yesterday.. He welded up his 12 bolt last saturday. It blew out the ring and pinion and broke one axle in half and cracked the other one on Sunday. He wanted to know if I new anybody with a 14bff for sale.. He is extremly hard on his rig and it was at Hollisterhills..
