12 Bolt Yoke Problem, 74 Jimmy
Discussion in 'The Garage' started by gstuck3, Aug 14, 2005.
  1. gstuck3
    gstuck3 Registered Member
    Mar 15, 2005
    51
    Twentynine Palms, CA
    Can I change out the yoke in my 12 bolt without changing the pinion preload or anything else important? I just had my gears done, 3.07 to 4.10, and Detroit Locker rear / Truetrac front installed. :D The shop that did them told me when I picked up the Jimmy, "Your rear yoke has a broken off bolt that someone has tried to repair". :doah: I wish they had just called me so I could have had them to fix it. The bolt broke off , was drilled and tapped one size bigger (3/8-20) with about 1/2 in. of thread, and a short Allen bolt was installed. With it having straps not u-bolts this sucks. Is there a 12 bolt yoke that is u-bolt not straps? I guess I need to put a "beg" in the parts needed forum.
  2. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    that sucks..I just scrapped a 12 bolt too!
    That sucks!--I had a junk 12 bolt posi I just junked a few weeks ago too! :doah: (it WAS a good rear end,but water got in it and rusted the gears to hell.)..I coulda sold it too ya cheep!(the yoke) :doah: :mad: :( ..---I have a front dana 44 off a 73 k10,is the 12 bolt the same yoke as a 10 bolt front one??.
    I think Moroso makes yokes that use "U" bolts for 12 bolt axles,but I'm not sure if they will work on trucks..something I read makes me think they dont work on truck applications...someone here must know more than I do about them.... :crazy:
  3. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I tried the moroso parts they don't work there designed for a car 12 bolt any lift on your truck and they hit the driveshaft. What you can do is drill all the holes out in the yoke and put bolts all the way thru and nuts on the back it is cheap and a good solution. Worked great for me until I went 1 ton.
  4. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    If you end up needing another yoke, I have one; complete with straps and bolts. Let me know.
    Jimbo
  5. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    I don't know that it is the right way, but yes you can change yokes with out messing with the crush sleeve/pre load. Even after the crush sleeve has started to crush, they take a lot of torque to change anything up with your settings..
  6. gstuck3
    Mar 15, 2005
    51
    Thanks for the info guys. I think I'll try Backyardbuilt's Idea first. If I screw thet up I'll probably be needing that yoke Jimbo. Wish me luck. I'm none too bright you know.
