12 bolt ?
Discussion in 'The Garage' started by hpuall, May 24, 2004.
  1. hpuall
    hpuall Newbie
    Jul 24, 2003
    nc
    rebuilding the 12 bolt rear end on my 78 k5 & got the pattern right and the backlash all set but can't get the dag um crush sleeve to crush impact won't bugde it and neither will a 2 foot cheater bar. looking for any kidda tips or advice. Preciate it.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    You are gonna have to redo all of the pattern and backlash when you get it crushed because it will change the pinion depth. I used a 6 ft cheater bar to crush the sleeve on my 14B. Get a little more leverage on there it'll go /forums/images/graemlins/thumb.gif
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I always like to use the handle off my Hi-Lift when things get really bad. Pretty good length of cheater pipe that is almost always available.
  4. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    No it won't!, If he had proper preload when he set it up the only thing that would change pinion depth is amount of shim under the head.
