12 bolt
Discussion in 'The Garage' started by sunnyc123abc, Jan 18, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    Well it looks like im am going to have to swap a 12 bolt in place of my 10 bolt, since a 14 ff is too pricey to swap in and time consuming for me right now. I was just wondering, what i would have to do to swap in a 12 bolt in place of my 10 bolt.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Change the u-joint , thats it .
    And if you undo your backing plates , and carefully lift off the brake assemblies , and tie them up over the axle , you could reuse your existing brakes and drums etc .
    I have a 12 bolt in mine , with my original 10 bolt brakes and lines . We just dropped the axle away from the truck brakeless :thumb:
    Forgot the u-joint number , just have to look in the ck5 part # post again !
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    BTW , you can use the 12 bolt brakes if you wish , the lines will mate to your truck .
    But beware that early 12 bolts had skinnier brake drums and shoes . Don't want those with a fullsize .
    If you can only find a 5 lugger , the 6 lug shafts will fit no problem .
    4 speed trucks had a 1350 yoke and is a great find .
    And carry some shafts , you may not break , but be ready if you do .
    I bang on mine with a locker to work , to trails , on trails , and on long trips :D
  4. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    he doesn't have much left of his brakes....look for the gorman thread in the pacific forum.
    sunny get a hold of me. I'll go pull the cover on the 12bolt I have today. and see if it's any good. What gears are you running?
  5. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Glad to see your gonna put the rear end in soon.
  6. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    Yea, Im trying to get the axle in this weekend. I need truck to drive to work. As for the ratio, i have no idea. But when i spin the front drive shaft 4 times, the wheels spin once. And Devin, my dad already bought a 12 bolt without me knowing:doah: . We are going to check it out this weekend. hopefully he didnt buy it yet. If I don't end up buying the one my dad found, I will probably be buying yours:D .
  7. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    no problem...either pm or get me on AIM and I'll give you the price on it. I checked today and it's got 3.73 gears with a limited slip in it. I have pictures in another thread.
    http://coloradok5.com/forums/showthread.php?t=162011
    your gear ratios should be stamped on the ring gear---if there's anything left:D. So where are our pictures of the carnage?
  8. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    iv been trying to get under there and open the cover, but i haven't had time, cause work. i will probably get the cover off this weekend
  9. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Was it exactly 4 times? It should be more or less. 3:73 vs. 4:10.
    Make a mark on your pinion and the housing and then on the ground and tire. Then rotate and count. Or you can just take the rear cover off since you already have to do that.
  10. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    The conversion u-joint I use is #372 at O'Reilly's. I don't remember the brand right now, but it's a lifetime warranty. It was their name brand joint. It cost me about $25 maybe a little less. :thumb:
    Rick
  11. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    Ok, so to my understanding i can either get a conversion u joint, or switch the 10 bolt yoke witht the 12 bolt yoke and get a new seal. Which way is better?
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I'd get the conversion joint , less hassle that way .
    I have swapped yokes before , and have had them work well , from a 12 bolt to a 12 bolt , but haven't swapped yokes from 10 to 12 before .
  13. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    Do you know the part number for the coversion u-joints? iv tried searching but can't come up with anything for my local parts stores, napa, autozone, kragen, pepboys, paw. thanks
  14. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    PM MIKE (supreme70). he just did this swap.
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The part number post has been visible from the forum index , and ttt twice this last 3 days :D
    1310 (12 bolt) to S44 (10 bolt) 3-3130
  16. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    If you want to 'keep it in the family' call Jess at High Angle Driveline. He just sent me a box of them!
