12 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pjwalters, Aug 2, 2001.
  1. pjwalters
    pjwalters Registered Member
    Jul 30, 2001
    11
    kansas city ks.
    is it worth $100.00 bucks to get a 12 bolt to replace my 10 that has a factory limited slip? Oh yeah the 12 has a mini spool also.
  2. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    id do it, easy as pie putting it in and you get a little more strength, and peice of mind. I'd also treat it like the 10 bolt cause it has the spool in it so you basically even it out on strength if you know what i mean
    sun desert offroad http://community.webshots.com/user/scoobydann
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Might take into consideration, is it the same gear ratio? if it is, then go for it.
    Keep it simple!
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    for $100 i would do it if it has the same gears if not then i wouldnt do it
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Does the 12 bolt have stock axles?If they are stock I dont think they will last long with the spool.
    "I AM THE HILIFT KING"<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't either.
    Tim
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    My friend is running a 12 bolt with a mini spool and 35's and is Throttle happy! He hasn't had any breakage in alittle over a year...
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
