12 bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 70_K5, Oct 14, 2002.
  1. 70_K5
    70_K5 Registered Member
    Feb 16, 2001
    25
    i have a 12 bolt on my 71 chevy, i was wondering if truck 12 bolts have the same strength as like a chevy muscle car 12 bolts?
    thanks for your responce
  2. Grim-Reaper
    7,385
    Atlanta
    Truck 12 bolts are 8 7/8 ring gear. I think it's a little bigger than the car version. I really should know this because my 70 Pontiac LeMans has a 12 LOL. I know there was some difference but it wasn't huge.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The GM car 12-bolt is also 8-7/8" but its a different animal - nothing interchanges. They are about the same for strength.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    as stated there are some small differances but not much they hold up better in cars cause they are not trying to turn such big tires lol /forums/images/graemlins/smile.gif
  5. 70_K5
    Feb 16, 2001
    25
    thanks everyone for the reply's, as for the big tires... it will not be turning any. it is a 2 wd pickup so i am just worried about the handling of some big HP.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you want something to handle big horse power then go with a 14ff and convert it to a six lug disk brake setup /forums/images/graemlins/smile.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    truck 12 bolt have alot smaller diameter of pinion gear stem than car 12 bolt
    car and truck 12 bolt are both same ring gear diamete of 8.875 and they are nothing alike in appearance, parts will not interchange between these two designs, only thing they have in common is that they are built by american axle for GM use and are 12 bolt covers and are two pinion design
