12 Bolts and Large tires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, Feb 25, 2002.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    WEll I was a very bad boy today. I put on layaway 42" tsl 42x15.50x15's Americas tire gave me a heck of a deal. STOMPED 4wheel parts. Anyhow after a long convo with Interco. I came to the conclusion of purchasing them. See 42's are only 12 lbs heavier than my 38's. I have had no drive train problems with my 38's and beefed 12bolt and 10 bolt. Who else runs large tires, wheels often, and doesnt have breakage?
    </font color=blue>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
    "If First you don't succeed, Destroy all attempts you've tried"
  2. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    Hmmm not me. I destroyed the front and rear 10 bolts running 36s. Thats an accomplishment if you can pull that off.
    <a target="_blank" href=http://community.webshots.com/user/runfordaborder>my baby</a>
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I am installing a set of 38" TrXus STS tires real soon. I have ran 37" Boggers for over a Year and have only broken one ring gear and a Gov-Lock. I have also broken numerous D44 shafts. I wheel quite often and am not bothered by the small amount of breakage I have had. Its not enough yet to make me lay down the price for those gold plated D60's.
    Mudzer 1978/91 K5
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    With a detroit locked 3:73 12 bolt rearend and 35" mud terrain tires...
    I'm on a role for one ring and pinion per year![​IMG][​IMG]
    For the last 3 years.
    [Real Men Don't Care About Gas Mileage Or Rapid Tire Wear!]<a target="_blank" href=http://coloradok5.com/gallery/albuo19>
    MY 1972 K/5</a>
    RyanB.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I broke the center section, bent a axle tube, sheared off all the lug nuts, broke the spider gears, and twisted a axle tube. All this in about 6 months with 36" TSL's. The 14BFF is just about ready to go in.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  6. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    your just special Dan ;-) yeah and its about time that 14blt goes to use !! hehe member loading it ? oh and i romp on ORD old 12 and 10 bolts all the time with my 35s and i cant seem to break em . romp as in "oh crap i floored it so hard my foot is stuck in the firewall!!" muhuahah [​IMG]
    &lt;a target="_blank" href=http://www.imagestation.com/album/pictures.html?id=4292257869&amp;show_all=1&amp;start=1&gt;wheeling and carnage pics&lt;/a&gt; <P ID="edit"><FONT class="small">Edited by K10ANDYKHAMNIC on 02/26/02 12:47 AM.</FONT></P>
  7. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I ran 35" BFG Mud T/A's on my 3:42 geared 12 bolt rear for 3-4 yrs, and it has taken the abuse of clutch dumping on and off the road. I have had no problems, even the gov-lock still works! Even the 10 bolt front has held up, I just grenaded the front driveshaft CV joint instead.
    [​IMG]psychoholicslag
  8. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Well, you might be able to get away with it....especially since you have been able to get by with 38's. It all depends on your driving style and what type of terrain you ride on.
    I wouldn't say "only 12 lbs.", that is a pretty significant increase over the already heavy 38's plus 12 lbs. of rotating mass at EACH corner will make a much bigger difference than just adding 48 lbs. of dead weight to the truck. Also, the added leverage of the taller tires will put more stress on drivetrain components.
  10. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    Add to that the 600 hp 396...
    My 12 bolt grenaded with 33's...on pavement.[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  11. BurbinOR
    5,829
    Oregon
  12. BlueKnight
    Mar 6, 2000
    1,518
    Oregon
    You know you make alot of Sense Frank. I can get a 14bolt ff pretty easy. a d60 well thats another matter all together. hm I'll just build the replacements in my spare time and when the day my diffs go i'll put in the other ones. Good idea.
    </font color=blue>
