@#^#$@# 12 bolts.. check this out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Feb 24, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Hey guys... ever have that problem where a simple job becomes complex?
    me and Brian(Or2play) were going to replace the seals and bearings in his 12 bolt today. thing is we get the axle on stands and the dif cover off and the tires and drums off. go to remove the king-pin retaining bolt. ONLY HALF OF IT CAME OUT!!! it was sheared off inside the king pin. so we tried to drive it out(with no luck.) he is in the looks for a 14 bolt anyway, but the drivers side is BAD and causing vibrations BAD. if anyone has a 14 bolt in the south AZ area it would be nice.
    anybody else had this problem?
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    They make a tool to remove the broken bolt. I had to buy one when I pulled the axle apart on my burb. Snap-On or Matco sells them
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I had the same thing happen to my 12B. I took off the bearing cap to get clearance to drill a hole in it then used a EZ-out to remove the rest of the cross pin retaining bolt. This is a VERY COMMON problem w/ 12 bolts. When I was trying to get a set of spider gears from the J/Y I had to open up 3 diffs befor I found one where the bolt came out in one piece! I also found out that GM used a different bolt in my axle and that they don't stock it. I ended up getting it from a tranny shop for $10 (about double what it should cost but it was his last one).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    this one was broken off so far down an EZ out would not have worked. otherwise i would have tried it.
    Grant
