12" lift & front driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 425 Xpedition, Aug 28, 2002.
  1. 425 Xpedition
    425 Xpedition 1/2 ton status
    Dec 4, 2001
    123
    Crosby, Texas
    12\" lift & front driveshaft
    I was wondering what everybody else is doing about the front driveshaft with the 12" lift? I am putting 44's and 12" springs on my truck. The driveshaft is hating life right now with the 10" springs, do not think it is gonna take it.
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: 12\" lift & front driveshaft
    I went to Arizona Drivelines for mine and I do not recommend them at all. They do not stand behind thier stuff and they will say whatever to get out of thier warrenty. I say this from experience.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Almost evey truck I see with 44"s and that much lift don't have a front shaft /forums/images/icons/shocked.gif /forums/images/icons/grin.gif
  5. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    ive heard alot of good about them...what exactly happened to u. and i plan on buyin my rear CV from em soon
    NITRO
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I spent about $900 on them. Real nice drivelines. I dont knock the quality at all. He told me that if I ever gernaded a rear CVC for the first year he would fix with no problem. I geranded one on the rocks after about three months. I called him and told him and he said send it in. I did and he fixed and sent it back. And billed my credit card that he still had on file like $250. I call and said WTF? He claimed that I had bottomed out the driveshaft and that it was not his fault. I pointed out that when I ordered them, all he wanted was the total rested length between the two yokes and what lift I was running and he could set it all up and that there is 6" of spline showing when it was at rest. No way was it going to bottom out. He then said that the driveline had a big dent in it and the force of that broke the shaft. I said well you didnt change the shaft and there is no dent in it. then he said that I wasnt clear on the situation and what was he supposed to do? I hung up and had my credit card cancel the charge. The guy that I run with got a front driveline from him and it was too long. The guy said to send it back and he would shorten it for just shipping. He charged him $220 just to shorten it and shipping. He also had to cancel the credit card charge.
    I will say that after all that. I have beaten them to death and have only had to change one U-joint. I am more careful in the rocks though.
  7. 425 Xpedition
    Dec 4, 2001
    123
    Crosby, Texas
    Well personally I cannot stand a big truck with no front driveshaft. Do not want to look like a poser with a big useless truck. Does anybody know how much Jessie might charge for the front shaft? Trying to figure out how much more I gotta spend on this thing.
  8. UseYourBlinker
    Jun 7, 2000
    11,117
    I wans't saying you were a poser...just glad to see you are gonna fix your the problem the right way... Got any pics of your rig? /forums/images/icons/grin.gif
  9. 425 Xpedition
    Dec 4, 2001
    123
    Crosby, Texas
    No problem, I did not take it that way. I am like you, I see alot of trucks running without front shafts. Why bother? I do not use my truck alot, but would like to know if I needed four wheel drive it would work. Will just have to keep trying to get a hold of Jessie and see what he tells me. Sorry no pictures yet.
  10. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    your options are an expensive driveline or rolling the front diff up 20 degree's - Jess /forums/images/icons/grin.gif
  11. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I have an '81 Crew Cab that Ive been debating whether or not to put a 12" lift and 44" tires under. It has an SM465 4spd and 205, and the front driveline is already at an bad angle with the 6" lift (gone through 2 CV joints this year).
    I have a '73 International parts truck that I'm now considering pulling the divorced 205 out of and mounting in the Crew cab, along with a 2wd SM465 that I have. Anyone think this is a possible solution? I figure the modifications to make that setup work would be easier and cheaper.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    curious how you can run a driveline without rolling the dif up 20degs
    I see your CV should handle the TC end but the dif end will be at an extreme angle.
    could you spell out your recommendations here?
    I have 10" springs and the dif turned, the springs are sick stiff so range of motion isnt that high
    no droop but have had the inner fenders ripped out by the tire while twisted up
    I have had only one driveline failure and that was the 1310CV exploding due to extreme abuse
    40 deg below zero, in REV, 4 lo, chains on, tied to a loaded cummins dodge that was in the ditch, hopping violently with repeated merciless attempts
  13. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I have 10" lift with a 4spd and D60 so my front drivehaft is pretty steep. I swapped in the fat 32 spline front output with a 1350 yoke on my 205, now I run a single 1350 joint on both ends of the front shaft and have had no problems. I also do not have any pinion angle mods or t-case drop.
    My set up has been like this for years with no problems. I do not have any u-joint breakage problems. I'm not a violent 4 wheeler but I by no means baby it either.
  14. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    that is a very possible soloution. and that is what i would do to be honest. i am going to run a divorced T case in my lazer i think. well divorced doubler..
    grant
  15. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Well my opinion is go with a dana60 then have the rear pitched by grinding off the knuckles then re-welding them. There is a guy here in south NJ that does it for $100-$150 I think.. I am gonna get him to do it to my dana 44. I have 14" front leafs and have my t-case lowered 2" and grinded out my yokes.... I AM VERY STEEP!!!! Check out this shot of my front... hard to see driveshaft.. but look to the left of passenger side leaf...
    I am only running 40"s and need to lower to 38's to get through nj inspection as that is the tallest tire allowed now. Also the other thing is I can only be 33" to bottom of door... so gotta come down some too.... /forums/images/icons/frown.gif
