12" lift, what about front driveline?
Discussion in 'The Garage' started by bigbadchev84, Jun 24, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i am installing a 12" lift on my 84 shortbox with a 465 and 208 combo, what are my options for a front driveline?
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    holy chit thats a lot of lift. show truck? anyway, if I was you I'd cut/rotate my front axle so the pinion points towards the case and go from there.
    j
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    no show truck, just mudder and occasional pavement pounder, had 8inch lift and 39.5, but wasnt big enough, the front driveline clicked with the 8 inch, i dont think it would even turn now. would a had shaft work?
  4. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I am pretty sure you could talk to Jess over at High Angle and come up with a sollution..
    Have you thought about going divorced on the case ? I have seen a couple of people that went that route and it worked..
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Why is anything with more than 4" of lift a show truck? People in my area have 20" of lift with 49" Iroks on Rockwells and 700+ horsepower and still get stuck in the mud. I wouldn't imagine it would be a practical set-up for rock crawling... but not all people crawl.
    Divorced is the route I took because I hate cv shafts. I have 7" suspension in this pic and not much angle on my driveshaft, I would imagine I could easily handle a 12" lift.
  6. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    if its a mud truck have you though of clocking your t-case down?
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep, get the diff clocked up, better pinion angle and you can keep your caster.
  8. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    clocked up? wouldnt it be down?
  9. divorced
    Jul 20, 2004
    5,115
    The differential would need to be clocked up so the pinion points to the transfer case. The transfer case might be able to be clocked down to ease the angles.
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    around here a guy rotates the axle.... he grinds the welds off and pitches the axle and then re-welds.... all for $100
  11. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
  12. RootBreaker
    Nov 29, 2001
    5,118
    173
  13. mudslinger99
    Oct 8, 2004
    512
    East Coast
  14. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    hey man im running the superlift 12" kit and before i did my doubler a few months ago i always just reworked the stock front d-shafts. i would just grind out the cv to clear a steeper angle and it always worked for me. With my new transfer cases i chose to call jesse at high angle and i went with 1410s-cvs- front and rear. the only downside to the higher lift springs(besides the obvious like stiff ride and no flex) is that when you really begin to beat on them theyll tend to bend alot easier. I dont know how many times I have bent my front leafs due to them being so arched they literally want to push backward . When i stuck to just the mud they worked great though. well good luck Later Ryan
  15. RootBreaker
    Nov 29, 2001
    5,118
    173
