12" lift
Discussion in 'OffRoad Design' started by ihatefords, Nov 19, 2004.
  1. ihatefords
    ihatefords Registered Member
    Nov 10, 2004
    28
    Wyoming
    12\" lift
    I need to know what will I have to do once I purchase a 12" lift and how this lift is going to affect my ride. I own a 1981 GMC sierra grande and I have to outdo the kids in town with a 12" lift.
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    Re: 12\" lift
    That is getting real tall. Do you run a lot of mud, deep water etc. that you need that much lift? I would suggest that you really think about less lift and cut the fenders to gain some room for big tires. That said I don't know what you will nee for a front spring, in teh rear you could use a 4" shackle flip and an 8" spring or a six inch spring with a 2" block might work better because your pinion angle is going to be ralley bad.
    With that much lift the ride is typically harsh to say the least and many problems start coming up with driveshaft angles, lengths, etc.
    Once agian I would look long and hard at the use for the truck if it were me.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Re: 12\" lift
    Longer brake lines, steering corrections, driveline modifications, shocks, u bolts. It will ride a bit stiffer. What brand of springs are you going to run?
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    Re: 12\" lift
    try posting something like this in the garage where it'll get more responses.
  5. ihatefords
    Nov 10, 2004
    28
    Wyoming
    Re: 12\" lift
    I was thinking about running a superlift swamprunner kit 12" lift springs. I also will be running a 3" body lift which is already on the truck. As of now I have a 2 1/2" Rancho lift and the body lift and am running 35's.
  6. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Re: 12\" lift
    I have the 12" springs + 1" ord zero rate up front with 6" skyjacker springs 1" zero rate + 4" ord shackle flip in the rear. I also have 3" body lift & bushwacker cut-out flares.
    I'm running 44" boggers. The /forums/images/graemlins/burb.gif does not ride bad because of the long wheel base. You should spend the extra $ on crossover steering & hydro assist along with 1 ton axles if you want to do it right the first time. Also you will be needing a lot more gearing.
