12 rear perch ??
Discussion in 'The Garage' started by bee32, Jan 22, 2003.
  1. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Anyone know for sure the measurements for a first generation 12 bolt leaf spring perches to go into an 83. I measured nine inches from the drum to the inner edge of the perch on my 10 bolt and 9 3/8 on the 12. Has anyone done this before? I did a search and couldn't find anything. I am mostly just looking for someone to verify my measurements. You would figure that an Aviation Structural Machinist could figure it out. Just lookin for some back up.Thanks for any help.
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Should be Bolt in swap.I know they are wider on 88 up.Put 12B under mine for while.Had to run shallow backspace wheels to clear springs on 88. /forums/images/graemlins/thumb.gif
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Ok Bee32
    I Measured mine at 7"3/4 from the flange to the outer edge of the Old pad and I got 6 1/2 to the block that someone put on my 12b This was done before I got the truck it's 83 as well.
    What we think it was, Is a 12b out of a 1st Gen truck and someone put a block on top of the old pad an welded it together I hope this will help you some what.
    Eric
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    what u have to do is measure the space in between the perches.what i did to make sure my 14 bolt would fit is put a straitedge from the perch down to the ground on either side.then measure the space inbetween them to see if the springs will line up properly without changing the perches.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You will have to move the perches out.
    1st Gen Blazers (69-72) had leaves that were closer together.
    The same goes for k30's
  6. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    Thanks for all the input. With all the snow we are getting it's gonna wait a week or two. I am getting the old perches off this weekend. But I appreciate all the help. Thanks Again!
