12 to 14 bolt
Discussion in 'The Garage' started by jhodge, Jul 31, 2003.
  1. jhodge
    jhodge Newbie
    Jul 31, 2003
    3
    Will a 1980 14 bolt fit under a 78 pu with a 12 bolt? Any major concerns?
    Thank you.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    this has been covered more that any other topic, save 33" tires.
    try a search.
    that is all.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    p.s.
    fill out your profile.
  4. jhodge
    jhodge Newbie
    Jul 31, 2003
    3
    sorry about the profile new user. I tried the search, I am sure that the info is there somewhere, but I have not found it yet. I dont have much time on the buy! just thought i would give it a shot.
  5. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    try a search.
    that is all.
    Save 33" tires? wtf does that mean?
    1 ton 14bolts have spring perches and shock mounts at different distances , so you hafta move those.
    3/4 ton 14bolts are direct bolt in.
    Van 14bolts are longer (not sure about spring perches) so the axle is just as long as the front unlike in any other axle.
    It is relly easy and pretty much bolt in. you'll need a new Ujoint at the driveshaft too, i believe it's called a 1350.
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    *sigh*
    the srping pearches will have to be rewelded, possible shock mounts also.
    you will need a conversion u-joint.
    the rear will be 8Lug the front 6Lug, so you will need to convert either the front or the rear. the fronts will need 8 lug conversion pieces from a 3/4 rig, the rear an adapter such as the one from Echobit.
    e-brake will work, but you might have to work the cables a bit. brake lines will also swap.
    Width will be the same, but will still be 1.5" narrower on each side than the front, unless yo get a Van 14BFF.
    that is all.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    save = except
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    It means this has been covered more than any other topic except 33" tires /forums/images/graemlins/rotfl.gif
  9. jhodge
    jhodge Newbie
    Jul 31, 2003
    3
    Thanks for the quick help! I think I will give it a try!
  10. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    If you got anymore ?'s don't hesitate to ask. Most of us are happy to help out with answer's. /forums/images/graemlins/thumb.gif
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    zakk, when you do your respond to some of these questions save them on your comp so you can just do the blanket answer to some of the common ones we see asked a lot...
    jhodge, if you do the change over you either need to move your leaf pads or buy new ones and weld them on ($45-$50 for the new pads) ,
    12 bolts have 6 lugs rims and 14 bolts have 8 lugs, you can either convert the 14 bolt to 6 lug (spacer rings and hub work $275-$325) or buy new rims( 15”steel rims$200-$250, remove and re- mount tires$80) and convert the front ($100)
    convert the 14 bolt to 6 lug = $300.00 ref
    new rims and convert front to 8 lug = $400.00 ref
  12. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the only one i saved is my disertation on 5.13's being the only gear choice for larger tires or those with 700R transmissions.
  13. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    here you can get 15" 8 bolt steel wheels for $26 each plus their handling charge.
