12 to 14sf yea or nay??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Feb 13, 2003.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    O.K. did search.. found out pro's and con's between 14sf and 14ff.. I have a lead on a 14sf w/ 4.10's new seals and brakes for $200.00 I currently have a 12 bolt w/ 3.54.. want to go w/ 4.10 anyways... Should I jump on this or hold out for the 14ff.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you are sticking with the 33" or going no more than 37" in the future, then it's a good price for a regear and a little more beef.
    If you think you are like most where you will keep going bigger then hold off for a 14FF.
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I don't know about down there, but up here you can buy a 14bolt FF for 200 bucks all day long. I wouldn't waste my time w/ a SF for that kind of $$.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Sounds like a good idea to me. /forums/images/graemlins/smile.gif
    John
  5. rcpilot
    Feb 22, 2002
    507
    Central Cali
    I have no immediate plans to go bigger, however the TDS run end of this month might change my mind! /forums/images/graemlins/thumb.gif Right now its a daily and until I get another form of transportation it won't get radical yet... However I do really want to go to 4.10's...
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You need to figure in the price for regearing the front aswell. For me, I found it cheaper to buy a matched set of 3/4 ton axles. I got both front and rear axles (14 bolt FF rear / Dana 44 front ) with matching gears (From 78 3/4 Ton pick up.) for $250.00 total cost.
  7. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Z3..I believe that I will wait and find a set.. Out here in the middle of no where..(El Centro, CA)aka "El Sweato".. /forums/images/graemlins/angryfire.gif there are trucks lying around.. /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/crewcab.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I believe that I will wait and find a set.. Out here in the middle of no where..(El Centro, CA)aka "El Sweato".. there are trucks lying around..
    [/ QUOTE ] If thats the case, maybe you'll get lucky and find something with a Dana 60 up front.
  9. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    The other half of the "?" is what are you going to do w/ the front? If its staying D44/10B then yes its a good idea. If you are going to use a D60 front then I would use a FF14B out back. Of course the usual tire size, usage, ect...
  10. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Is wheel track an issue???
    The FF is about 4-6" wider at the wheel fange than the SF
    The FF is a 10.5 ring gear if I remember, and the other is 9.5..I may be wrong about that...
    The FF is SIGNIFICANTLY heavier than the other...
    The weight is all in the hubs, brake drums and spindles...something like 150 or 175 lbs..more...
    More unsprung weight, crapy ride...
    FF hub durms are hideously expensive..as are the brake shoes..
    Just some things to consider /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  11. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Was planning on keeping the D44 up front.. I'm not going to be doing major rocks.. its a daily driver with weekend playing.. I now have 33's w/ 4" lift and 3.54's want to go to 4.10 and then up to 35's..
  12. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    [/ QUOTE ] Where did you hear this?
  13. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    maybe he is talkin about the hubs on the ff??? /forums/images/graemlins/confused.gif
