12 volt shock
Discussion in 'The Lounge' started by mountainexplorer, Jan 3, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I had a battery fly down and hit the header in my shortbed yesterday. I grabbed it to get it out of the way, and as I was leaning over the core support holding onto the battery, I felt electricity going through my right arm.
    All said and done, afterwards I felt the spot where my stomach was leaning on the core support, and there was this big red spot, and a tiny hole in my shirt there. At first I thought it was just from having my weight on that spot... but the spot is still there like a minor burn on my skin.
    I didn't think 12 volts was enough to do that.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    its not the volts its the amps, amps caused the heat, the inside of the BAtt. would have been real hott, more than a min. and there is a real good chance it would have exploded, ask me how i know:D
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    LOL.
    I went wheeling a few months back. Got up about 3 miles into some rock strewn debris and was bouncing around pretty good. Smoke starts coming back through the cowl. Thought I had nicked the lower radiator hose but the battery had fallen back into the header. Had a nice hole in a brand new battery. Forgot to strap it back down when I replaced it the day before. 70.00 down the crapper. ack. :what:
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    :D:D:D
    Come back when you've been hit with 50,000 volts...............
    :p:
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    owwwww i got hit fron the HEI that hurts, and from a 220 dryer outlet that was supposed to be dead(stupid sparkys) that wasent fun eaither
  6. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Ya might be a little on the crispy side but everyone loves bacon in the morning. :D
  7. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    It was the current... 300 milliamps can give you a big shock if it passes through your body, too...
  8. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I know how you feel.
    When i was a younger, stupider me i wrongfully exposed my body to a 17KVdc jolt from a radar transmitter cap rack/ pulse forming network.
    All i remember was waking up on hte floor and not being able to see...everything was white.
    Got a free 24 hour stay in the hospital for that one, and i assure you it will not happen again
  9. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    I'm always afraid of getting electrocuted... Seems most things I do to any of my vehicles involve electricity... On top of that, I'm pretty good at sending sparks flying with just about every project :haha:
    Installing subs and an amp is especially stressful, especially after the initial spark is sent. I've almost got it down to where I can do it without sparks, but it just happens.... Using jumper cables scares the piss out of me... Sometimes nothing happens, other times I think I'm going to die with all the sparks and loud popping noises.........
    Maybe I should just not do anything that involves my battery............ But then I wouldn't be able to do anything... I guess suspension stuff doesn't really involve the battery... Just the wonderful thought of what if I pull the wrench too hard and the truck falls off the jack and it's sitting there with the springs out and no tires, I'd be out a Jeep... Of course, there's no real danger involved. Every time I've messed with suspensions I've had the pleasure of using a hydraulic lift, air tools, a highly trained mechanic at my side, and a heated garage :saweet:
  10. Storm Trooper
    Nov 24, 2000
    4,640
    When I was younger, I was jumping my 70SS Chevelle with my 71 Chevelle and had done the battery to battery connection many dumb times before without a problem. This time, the second I touched the last connection to the battery, BOOM!! :yikes: The battery blew the whole top off and lucky for me, I kinda duct before it got be bad. I was really lucky.
    NEVER HOOK BATTERY TO BATTERY! Always hook the last connection to ground on some metal, away from the battery. It can and does happen.
  11. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I hooked up jumpers on my big big truk bakcwards and it started smoking, I haven;t touched it since....
    I need to go jump it soon
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    "electrocuted" by 12 volts? give me a break. i get zapped with 100a 110v almost daily, customers not taking care of their shore cords on their motorhomes. grab ahold of it to unplug. *zap*
