123
Discussion in '1982-Present GM Diesel' started by USAJon, Jan 20, 2007.
  1. USAJon
    USAJon 1/2 ton status
    Sep 8, 2006
    125
    Silver Spring, Maryland U.S.A.
    123
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I know it's been done, how successfull it is in DD I don't know but some drag trucks do this.
    You could find info on that particular setup on www.thedieselpage.com
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,370
    E-town baby!
    MarineDiesel builds several verions of blown and intercooled 6.5 diesels. One version is 300 hp and 515 lbs of torque...
    IIRC they use a Lysholm twin screw supercharger.
    http://www.marinedieselusa.com/MD300-IB-1.pdf
    Not sure if that helps any.
    Rene
  4. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    I think you would have better results from a turbo or turbos. The biggest problem as I understand it is how much fuel you can push through the DB2 injection pump. Somewhere on the dieselpage is a video of a guy from Holland running a pulling tractor running 2 pumps to get enough fuel into the motor.
    George
  5. USAJon
    Sep 8, 2006
    125
    123
  6. USAJon
    Sep 8, 2006
    125
    123
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,370
    E-town baby!
    All the DB2 pumps are adjustable, however they do have a maximum amount of fuel they can supply. The injectors also have a max amount they can supply...the 6.5 TD injectors flow the most fuel. you want the DB4911 pump and the 6.5 TD injectors for max fuel delivery.
    Rene
  8. smalltruckbigcid
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Thanks Rene now I gotta go down to diesel components tomrrow and ask the pump guy more questions:bow::haha:
    George
  9. USAJon
    Sep 8, 2006
    125
    123
  10. filo
    filo Registered Member
    Mar 11, 2006
    96
    Anoka, Minnesota
    from what I've heard, another way to make good power is throw low compression pistons in a 6.2 or 6.5 and up the turbo pressure. It's supposed to make the same hp and torque as the new diesels. FWIW
