123
Discussion in '1982-Present GM Diesel' started by USAJon, Feb 23, 2007.
  1. USAJon
    USAJon 1/2 ton status
    Sep 8, 2006
    125
    Silver Spring, Maryland U.S.A.
    123
  2. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    Might get lucky..
    It might just need a new nylon govenor gear in the tranny,if it has only first and reverse..that is a cheap and easy fix..My 81 G10 van had the same dilema when I bought it in 1990 for 500 bucks ,the for sale sign said "needs a tranny".:rolleyes: ...it was only 9 years old in in good condition otherwise..(had a lockup TH350 in it)..
    I simply yanked out another govenor from a junk tranny at the boneyard and dropped it in,and I had all 3 speeds again!,,I've driven it over 50K since with zero tranny troubles..
    The 700R4's are very sensitive to having the TV cable adjusted correctly--do it wrong and they toast up in a few miles--but usually they shift weird ,or shift at the wrong speed,slip,and hunt between overdrive and drive when its maladjusted,or if the tranny is failing internally..I'd guess if you have first and reverse and it isn't slipping,you might luck out and just need the govenor gear ...:crazy:
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I second that. :D
    I bought one once that did the same thing, I was told the governor could be bad so I look and there was no governor :)
    Put one in and drove fine for years.
  4. USAJon
    Sep 8, 2006
    125
    123
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    It's right next to the speedo cable, about 2.5" round cover.
  6. USAJon
    Sep 8, 2006
    125
    123
  7. USAJon
    Sep 8, 2006
    125
    123
  8. USAJon
    Sep 8, 2006
    125
    123
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    What ring?
    There should be a wire strap like the one that holds the Brake so MC cover.
    Then the cover will pop riht out.
    You are probably taking the C clip off the pump, you don't want to remove that one.
    The 4" will be more than enough to take the governor off, it's not even 4" long
  10. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yep, you are on the wrong side methinks. Definately. It's on the driver's side right above the rear of the pan. The mount is just beyond, or behind, it.
  11. USAJon
    Sep 8, 2006
    125
    123
  12. USAJon
    Sep 8, 2006
    125
    123
  13. USAJon
    Sep 8, 2006
    125
    123
  14. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    well it could be blown but to answer the governonr question:
    when you have it ou, check to see if when you open the weighs the valve slides up or down?
