12B 2wd vs 4wd
Discussion in 'The Garage' started by Thumper, Jul 28, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I have a buddy with a 2wd 12B rear end. He wants to buy the 4:56 gears from my 4wd 12B rear... would they fit? Also, he needs a carrier... my TruTrac is toast. He could pick up a spool for a 4wd 12B and it would fit in? What are the differences between the housings? Can he swap in example a 12B spool, his 5 lug axles, and my 4:56 gears into my housing which is setup for rear discs?
    Mike
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Is his 12b 2wd axle from a truck, if so it should fit. The axles are interchangable. the only thing that may give your friend problems is if someone else put a car 12 bolt in the place of the truck one. Then the housing will be to small for your carrier.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    AFAIK as long as they are both truck 12 bolts then the carriers and gears will interchange. 12 bolt truck and 12 bolt car axles are different though and nothing inside will interchange.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The 5 lug stuff will fit in yours and vice versa . I sent my 5 lug shafts to iceman44 and he sent me 6 lug shafts when I bought my 12 bolt , perfect fit . Now the difference I found with the 4wd and 2wd housings is the driver side shock mount is a little low . I have to run that shock upside down or the body hits the axletube . I have seen 4wd axles with my same flip lift where the shocks still fit fine /forums/images/graemlins/k5.gif
