12B carrier question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaptCrunch, Oct 2, 2001.
  1. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Still looking for a 14B FF w/ 4.56's and not having a lot of luck. So I might end up redoing the 12B I have... but basically I bought the 12B w/ 4.10's in it. I have no idea if it is factory or not... but does anyone know how to identify which carrier is in it (3.40 and lower or 3.73 and higher) ? It is an open carrier and if I remember right it is out of a mid to late 70's pickup. TIA.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I got this from Randy's ring and pinion.
    12 Bolt Truck 2.73 &amp; down / 2.76 to 3.42 / 3.73 &amp; up #
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    I'll try to help ya, if the ring gear was 1/3 " to far to the left or right could you notice it ?
    That's what the carrier brake does it moves the mounting of the ring gear to the left or right !
    If say you happen to have the 3.07:1-3.73:1 carrier and your ratio is 4.09-4.11:1 then you have
    an extra thick ring gear, or possibly a spacer.
    The extra thich ring gear will be about 1/3" thicker than a non-extra-thick ring gear.
  4. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    Thanks for the help Ex... It doesn't look as thick as a ring gear on a smaller carrier would be. I know what you are saying. I just figured it would be good to check. Although it looks like if it was the smaller carrier I would be SOL cause they don't make it [​IMG]
    -Mikey
  5. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Motive makes both carriers for the 12 bolt.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
