12bolt help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, Nov 5, 2000.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    i bought this 12 bolt rear for my 89 k5 and am rebuilding it but have a problem with the c clip one came off no problem the other is stuck to the axle shaft i ordered new axle shafts but how do i get it out i try to use a punch but still wont move can i cut the shaft to remove it or what thanks for your help
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Uhhhh, don't use a punch. It should slip right off after the axle is pushed in, rotate the carrier a little. Unless you're swapping carriers bearings et al and don't care about metal shards in a precision component- then get a bigger hammer[​IMG][​IMG]
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  3. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    your axle may have a groove worn into it at the outer bearing and can't slide in far enough to let the c clip fall out. Wiggle the axle and tap it in toward center first with a small hammer and then increase hammer size as necessary. I had one axle that required a 16 pound sledge.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ok, here is my explanation.
    The clip is shaped like and C , you have to rotate the carrier until you can see the back(fully closed part) of the C clip. Then grap it with a pair of needlenose pliers or something similar and pull it out.
    The center pin of the carrier must be removed to do this and the axle needs to be pushed in towards the center of the diff. Make sure your e-brake isnt on so you can push in the axle easier.
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
