12bolt pinion torque
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Jan 17, 2001.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    My rear pinion seal was bad, leaking all over so today when im changing it the bolt on the pinion came off with my fingers! Since it was so loose i could not mark it so i would know where to stop tighting it. so what is the torque for this bad boy?
    [​IMG] [​IMG]
  2. dyeager535
    26,980
    there is no torque setting that I know of for your situation. They are torqued on to X foot pounds when new, then when you remove them, like you said, you are supposed to mark the threads. I had two loose pinion nuts on my trucks though, one I ended up replacing the yoke. I didn't do it "by the book" however I didn't have any problems. Just left the truck on the ground, parking brake on, and took the breaker bar and wrenched on it till I thought it was good. Never leaked again, nor did it wear out. BTW, my leak was BECAUSE the nut was loose, not cause the seal was bad...much easier fix : )
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Someone is right, it could be 100 lbs./ft. , or it could be 250 lbs./ft.
    Do you feel lucky today ?
    If you want to do it right, you need to disasemble the rear end, at least remove the axle shafts.
    Please understand Pinion Bearing Preload !
    Good luck
  4. dyeager535
    26,980
    better yet DON'T learn about pinion bearing preload, 'cause then you'll wonder if it's gonna come apart on you all the time : )
    Dorian
  5. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    you have a crush sleeve in the pinoin odds are that crush sleeve was already "crushed" which requires x amount of ft.pounds, i would just use a breaker bar and snug it back up not really putting the monkey grind on it.
