12bolt question
Discussion in 'The Garage' started by sunnyc123abc, Feb 2, 2006.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    If i swap my 10 bolt yoke to my 12 bolt yoke, do i just use the 10 bolt pinion seal, or do i need a special seal. and if i need a special seal, does anyone have a part number. Thanks
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have never swapped from yoke from 10 to 12 . But I would assume if the splines are the same the inner diameter would be the same .
    I do know the size of the yoke matters . When I put the lower geared axle in , and swapped my yoke over , it sprayed oil . 1350 and 1310 takes seperate seals .
