12bolt rear help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, Nov 5, 2000.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    i bought this 12 bolt rear for my 89 k5 and am rebuilding it but have a problem with the c clip one came off no problem the other is stuck to the axle shaft i ordered new axle shafts but how do i get it out i try to use a punch but still wont move can i cut the shaft to remove it or what thanks for your help
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    don't cut anything! Take a hammer and bash in the axle, where the lugs are, the axle should move in. The tention will be off the clip. Then it should just pop off with a screw driver...........JS PS....you might want to put a piece of wood between the axle and the hammer
