12v power supply
Discussion in 'Audio' started by '73 K5, Jul 24, 2003.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    So I've been thinking for a while about getting a 12v power supply to make myself a little testbench out in the garage. I've got a pile of car audio stuff I want to put on eBay, but I want to test it all before I ship it off. So I got on eBay and typed in "12 volt power supply" and got a few hundred hits.
    Thats why I'm here. I don't have the slightest idea what is a good brand and what is a bad brand. That test equipment stuff is not my area of expertise. Anybody have experience with this? What should I buy? And how many amps? I was thinking 30-40 so it could hang with some of the bigger amplifiers I would hook up...does this sound about right?
    THANKS!
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    If you just want to test out the stuff to see if it works the easiest and cheapest thing to do is use a spare car battery (lots of amps) or run a 16 guage wire from the one in your truck to the garage (disconnect the terminals from the truck first). A battery charger would also work, as would the power supply out of a computer (it not 30-40 amps but you should be able to test with it) ... lots of things have a 12V supply or were you interested in spending money? /forums/images/graemlins/tongue.gif
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    The suggestions the Rampage gave are pretty good.
    If you just really want a real power supply then I'd say go with an Astron. 30-40amps will be more than enough for radios and small amps but if you want to test larger amps then you might run into some problems.
    The Astron power supplies can be found on ebay pretty easily or from several online stores. They are primarily used for radio transceivers etc so they are filtered pretty well and have little noise on the output voltage.
    If you want something a bit bigger I can point you to a link for a 150amp unregulated power supply.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you just want too power the components up too test them, don't waste your money on a power suply. Just use a car batt. Heck, you could buy a car batt. and a trickle charger cheaper then a "Good" power suply.
  5. '73 K5
    1,763
    Kansas
    I guess I should have explained better why I wanted a dedicated power supply. I've used batteries and chargers before to test stuff, but it was usually a PITA. I got spoiled when I used to install fulltime. Our bay had a testbench with a deck and a couple of 5.25's and of course a power supply to run it. During the day we hooked up all kinds of stuff to it to pump some tunes into the bay. I'd kind of like to do that in the garage...use it for a garage stereo...and a test bench. We ran that thing 10 hours a day, 6 days a week and it was still going strong after years.
    Maybe I just need to sneek back in the shop and pop the top off their setup and see what kind of power supply it is. Thanks for all the advice.
