1330 to 1350 conversion u-joint
Discussion in 'The Garage' started by lrazer, Oct 19, 2005.
  1. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    i need a 1330 to 1350 conversion ujoint. does anyone have any part numbers or suggestions on where to get one?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    The Napa PN 447 is a 1330-1350 combo joint used in going from a 10 bolt to a 14 bolt.
    The Napa PN 348 is a 1310-1350 combo joint used when going from 12 bolt to 14 bolt.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    The 447 is a Saginaw 44 Joint to a 1350. NOT a 1330.
    73-87 trucks never came with a 1330, its a S44.
    If the original poster really wants a 1330 to 1350 joint its Neapco PN 2-3050.
    1310-1350 is Neapco PN - 3-3140
    S44-1350 is Neapco PN - 2-1153
  4. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    i have a 89 blazer that had a 10b in it, the ujoints have inside clips. i was told it was a 1330 to 1350 that i needed to go to a 14b. is this correct or no?
    i have already tried a 1310 to 1350 and this is not the correct u-joint
  5. mechted
    Oct 19, 2003
    765
    Granbury, TX
    S44 to 14bolt joint is correct one.... i just pulled those p/n's from the part numbers post without thinking about it, sorry
  6. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I have a Car-quest u-joint book. It shows a 1330-1350 conversion joint as a p/n 2-3050. If you don't have a Car-quest, NAPA should be able to cross-reference it.
  7. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    You need a S44 to 1350.
    Neapco PN 2-1153
  8. blasterD
    May 24, 2003
    410
    Anchorage Alaska
    sorry, I didn't catch that 2nd post. A Car-quest s44-1350 joint is p/n 2-1153.
