1330 yokes for 12 bolt and 203 with a cv shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, May 20, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Upgraded to 1330 cv shaft in the back but need info on the yokes. Anybody have part numbers? If not, then how about the spline count for each? How about the length and diameter? I should be able to use the stock part number seal in each end right? Help me out guys cuz I'd love to run with the new shaft this weekend.
  2. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Come on, ANYBODY? Seems some folks have used 1330 10 bolt yokes on their 12 bolt but what about the 203 t-case? 1330 outputs never came on a 203, would a 208 1330 output fit? What seals?
  3. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    So am I to assume that I'll have to just get a 1350 cv yoke for the t-case and run a conversion joint on that end? A 10 bolt 1330 yoke will fit, right?
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Some 3/4 ton trucks came with the 203.
    Keep looking, maybe you will find a 1330 for it...sorry I can't be more help...
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    1330 came on the earlier bronco's and is still available new but the seal is 1 7/8 -yours is 2 1/8 i have all the interchange #s at work if you need them give me a ring i'll be happy to help- 530-877-2875 - as for the 1330 for the 12 bolt it was only available 1- 2years max- you can run a 1350 for less money with u bolts - 65.00$ alot better than 1330- Jess
  6. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks man, appreciate the input.
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    iv got 1350 on my 203. didnt get the CV, wish i had. but my 12 bolt has a 1350 also.
    grant
