1350 --> driveshaft
Discussion in 'The Garage' started by blazerpro79, Oct 10, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    hey guys, i was thinking about upgrading to 1410 or 1350 u joints, being that i need new yokes, and i should just upgrade now, but if i buy new yokes, my driveshaft wont fit the 1310s. do they make a combo joint or do i have to just get new ears welded onto my driveshaft to fit the bigger u joint. this is for my 79 k5, info in my signature.
    also, any reason why i should upgrade to 1410 over 1350 or 1310? it see's 95% street/highway, not too much offroading.
    thanks in advance
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I'm pretty sure you have to rebuild you d-lines
  3. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    for the way you use your rig, I'd just stick with 1310s. Why spend the extra money? I have 1410s personally, but my rig is built to wheel.
    j
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have 1310 rear driveshaft yoke , and 12 bolt yoke on the prettier truck I drive everyday .
    I do wheel it , and haven't had it break yet .
    jekbrowns right , you probably don't need it with how you use your truck .
  5. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    ok, well i keep breaking u joints, because my 203 yoke is cracked... if i buy 1310s, do i need to get my shaft re-machined to accept the 1310 u joint, or do they make a u joint that will connect the two?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If your running a automatic/203 and 12 bolt , you should already be 1310 if its untouched original .
    If your breaking u-joints , just fix the reason , get a new 203 yoke , and make sure your angles are right and the shafts the right length .
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am still running 1310's and even an S44 CV in the front. If you are worried get the new cold forged spicer 1310's. I haven't hurt mine in the last year of flogging it.
  8. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i used to break 1310's when i was on 10 bolts and 33's... id say its worth the upgrade
  9. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    ok cool, so 1310 is stock size? sorry if i seem to be a noob in this area, its because i am.
  10. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    also, i think i will be replacing the rear yoke as well. it is a 12 bolt, but ive been told my yoke is a 10 bolt yoke. it doesnt have the ears that hold the ujoint centered... and it uses straps instead of a u-bolt. is that correct it is a 10 bolt yoke? either way, its hard to center it so i will be swapping it out as well.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They came in straps on 12 bolts too . The difference is the 10 bolt yoke is either s44 ( like 1330 but not exact ) , or 1350 on 4 speed trucks .
  12. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    To answer your first question, yes they make combo joints for just about any size. I don't have the part #, but I'm sure someone on here does. I have one that goes from my 12 axle to my 10 bolt driveshaft and have never broke it yet, I can get on the throttle pretty hard when we are wheeling too.
    Rick
  13. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I dug out the number the other day
    The joint to go from 10 bolt shaft to 12 bolt ( auto truck ) shaft is 3-3130 .
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Easy , go the post your part number post in the member center under tech articles :D
  15. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    BTW, you can't just replace the yoke on the rear end. It uses a crush sleeve and you will mess up the pinion bearing preload if you remove the yoke. Unless you can disassemble your differential and have an inch pound torque wrench, don't take that yoke off. Don't bother replacing the yoke, just wait until you swap in the FF14 bolt and uses a combo 1310/1350 joint at the axle end and you will be fine.
  16. 1977k5
    May 26, 2003
    9,994
    130
    Mine is a factory 4 speed and had 1310 u-joints from the factory (my dad is the original owner, so I know it hasn't been messed with), so not all factory 4 speeds have 1350 joints.
  17. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    seriously, for your use the whole 1350/1410 thing is a waste of ca$h. Upgrading yokes on an axle like a 12b is a little bit silly. Fix the yoke problem on the 203, make sure your shaft is operating as a sane angle and replace the joints. You'll be fine and it'll cost you a lot less.
    j
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Of course the assembly line isn't stopping , so I assume they would of used any combination they had on hand . The ones I have seen were 1350 , including the 70's truck my 12 bolt came from :D
  19. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    I take it you WANT to be banned. good grief, I'm averting my virgin eyes as we speak.
    j
  20. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    And I thought I was just being overly sensitive! :rolleyes:
