1350 U-bolt pinion flange for 14-bolt?
Discussion in 'The Garage' started by rcamacho, Dec 31, 2004.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm running a 14bolt ff with a 1350 based shaft. The pinion flange is the weak strap type. Anyone out there have a source for U-bolt type 1350 flanges? I'd rather not convert to 1410 if possible.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    are you talking about the yoke?? If so just drill out the threaded part and get some u-bolts for it.:xmas:
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I believe H.A.D. offers what you want.
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    Cool, uh who or what is H.A.D? URL?
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Cool, cheap and simple
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    some yokes you can drill out and get ubolts for, the back side is not flat for a nut to sit on.
    my guess would be jess at HAD
    i have one i got from a 14bsf that has a different style strap and the back is flat for the nut to sit good. not sure if it will fit a 14bff or not.
  7. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
  8. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Call Jesse and High Angle Driveline. He has just what you need and I think it costs around $40 including ubolts.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Jesse does not offer a 1350 yoke with U bolts. There isn't enough meat in the yoke to mill it and not lose strength in the process.
    Go to 1410 or deal with the straps are your choices.
  10. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks. I'll consider the 1410 if and when I go to a different xfer case.
