14 b ff
Discussion in 'The Garage' started by t's85chevyk5, Jan 31, 2004.
  1. t's85chevyk5
    t's85chevyk5 Registered Member
    Jan 29, 2004
    66
    Phoenix, AZ
    is $200 a good price on a 14 bolt ff? It has 4.10 gears i believe /forums/images/graemlins/k5.gif
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    it is if it has good brakes and is otherwise complete, big brakes are expensive to redo if they need replacing, expect to spend almost 150 to redo them if they are shot.
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    bolt in is easy if from a 3/4 ton truck. if not, then it should be in great shape. Pull the cover and look for any
    visible gear wear or damage.
  4. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    i think its been sitting for a few years, so you bring up a good point. A guy from work was going to sell it to me. Im interested cause i think i feel my gov loc going out and i cant justify dumping money into a new carrier for the crappy ten bolt
  5. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    it is from a 76 3/4 ton chevy. My concernis will 15 inch wheels fit in there
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    for 200 bucks, tell him to remove all the drum brake stuff himself and to buy you the az-kickin disc brake brackets..
    id offer 100 bucks, it will bolt right in, and with the disc brake kit, you can clear 15"s...
  7. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    how much does the rear disc set up cost?
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Thats what i would do also. If you have to do brakes, would be a good time to do disc.
  9. Confedneck
    Nov 1, 2002
    5,236
    80+15 shipping for the brackets, bolts and spacers from azkickin,
    AZ Kickin Offroads 14bff kit
    we have this installed on my buddy (chevy4wd)'s truck, the pieces are seriously stout and HIGH quality..
  10. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    thats w/ loaded calipers and rotors?
  11. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    If you buy everything new for the disc set-up it should be under $200 including brakets, pads, calipers, rotors, bolts, hoses and lines, and new wheel studs. It depends on local prices on this stuff though.
  12. Confedneck
    Nov 1, 2002
    5,236
    no.. you still have to buy those, so for say, 200 bucks or so you can have complete rear disc setup..and its worth it.. but to run 6 lug you need wheel adapters and also need to have the 14bff hubs and axle shafts turned down to fit most 15" wheels..
  13. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    i just anwered my own question , nevermind that last comment. thanks
  14. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    im a student and am just wondering about the most cost effectiv thing to do with my rear end.
  15. Confedneck
    Nov 1, 2002
    5,236
    as for cost effective compared to longjevity, there is no other option i would consider...14bff all the way
    i was also a student not too long ago.. and when i blew out my 10 bolt govlovk, i replaced it with a 12 bolt rear i got for 50 bucks, and sold parts off the other 12 bolt i got shafts from and made money on the swap.. otherwise i would have gone 14bff, but being my DD, the chevrolet had to be back on the road asap, and as cheap as possible..
    if you have downtime, and the funds, i would definately do the 14bff swap with disc brakes.. you wont regret it..
  16. t's85chevyk5
    Jan 29, 2004
    66
    Phoenix, AZ
    another concern would be the front gears if i went w/ that 10 bolt. if i changed the ring and pinion to 4.10s would i have to get a new carrier. But it is hard to tear up a 14b ff with a 305. it would last me a while and i want to put a vortec 350 in this summer. i dont think that 10 bolt would be very fond of 300 hp or so.
  17. burbBoy
    Feb 4, 2002
    358
    WI
    I would definatly do the disc set=up before re-doing the drums. I too am a poor student and after wheeling with drums and chewing them up once a year at $40 a set for shoes plus any of the other crap it got way expensive. New pads are what $10. and it takes like 5 min. to change them out. The ultra cheap way to do it is find some caliper brakets and calipers from the bone yard off a dana 44 front and weld em on the 14 bolt. Also, check around on rotor prices. They jumped around from $35-$60 at different parts stores. My burb stops better now with one tons and 40's then it did stock. Hope this helps to get yet another 14 bolt some stopping power /forums/images/graemlins/smile.gif
  18. Confedneck
    Nov 1, 2002
    5,236
    what gears do you have now?? my 350 doesnt make 200 hp, not anywhere near it and i blew up a 10 bolt.. it all depends on your style of driving as well..
  19. burbBoy
    Feb 4, 2002
    358
    WI
    Oh and pull the cover and make sure it doesnt have a sh!tty Gov-Loc in it either.
  20. Confedneck
    Nov 1, 2002
    5,236
    govlock in a 14bff is a MAJOR improvement over its 10 bolt bretheren.. trust me, theres a chevrolet in town with a stout 350 and a 14bff with govlock and it survives just fine..
