14 BFF 4.56 thick gears
Discussion in 'The Garage' started by sandy78, Dec 28, 2006.
  1. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    How can you tell if you have the thick ring gear for the 4.10 carrier, or the standard thickness for the 4.56 carrier? Does anyone have a quick measurement? I'm trying to identify. Thanks in advance for any help.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
  3. sandy78
    Nov 28, 2002
    84
    Utah
    Thanks for the suggestion. I found a pic of cases, but not of thick vs. thin ring gear. To clarify, I have a ring gear that the guy I got it from said was a thick gear, but I don't have any way to verify other than to try to install it. I was hoping for a quick height/thickness measurment so that I would know if it was truly thick before I tear everything apart. The markings do not help. It is a 4.56 ring and pinion.
    Thanks!
  4. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    a regular ring gear is just over an inch thick. a thick gear is around 2" thick.
