14 bff or 14bsf 15" wheels?
Discussion in 'The Garage' started by franco802, Dec 30, 2006.
  1. franco802
    franco802 1/2 ton status
    Oct 16, 2004
    270
    San Diego, CA
    One thing I did search for before asking this is, if 15" wheels will fit a 14bff or 14bsf rear. I found mixed reviews on this because of drum size. So anyone here have a clear answer? Some people say yes, some no. I have brand new 35x12.5 15 bfg muds on my rig. I don't want to go out and buy new 16's.
  2. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    15 wheels will clear both i believe. its just the front 60s u have to grind the caliper. are u goin w/ a 8 lug conversion on the front 10 bolt?
  3. franco802
    Oct 16, 2004
    270
    San Diego, CA
    I will in the near future.
  4. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    i thought about doing that, but im just gonna save for 1 tons and do it all at one time. ive still gotta do something w/ my factory 10 bolt rear. do u know how i can find out if ive got a gov bomb or limited slip?? i looked in the glove box and evidently the previous owner replaced it and so no stickers. and i dont wanna pull the cover off yet. ive got a ring and pinion to put in there but i need to know if i just blew the spider gears or if i blew the gov loc. and u cant put a lock right in the gov lock can u??
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    15's clear the FF 14, but the SF might need a bit of grinding on the drums to make the 15's clear. The SF drums tuck farther into the rim and on my buddy's truck that had a 14 SF we had to grind down the fins on the drums a little to ge the rims to seat.
    8 lug 10 bolt front or D44 will need some grinding, and a D60 front will need a fari amount of grinding to get 15's to fit.
    Rene
  6. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    or run wheels w/ 2.5 backspacing or less right??
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Less backspacing means less grinding...but it also means tires sticking further out and a bit more stress on wheel bearings.
    Rene
  8. franco802
    Oct 16, 2004
    270
    San Diego, CA
    Some excellent info, thank you.
  9. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I have 2 sets of 15" 8 lugs. 1st set is an 8" wide with IIRC 4.25" b/s. My 89 has a 14ff from a 3/4 ton with slip on drums. They hit the fins on the drum, but some washers to see if it would clear, and with about 1/2" or so it was fine. (Didn't drive it like this!!!!) Other set is 12" wide with 3.25 or 3.5, can't remember. They clear no problems.
  10. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Ah crap.....
    I thought the 14bsf I was going to buy would be more bolt on than that. :mad: :angry1: :angry1:
  11. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    ive seen a disc brake swap for it, and it uses dana 44 rotors. so will it clear a regular 15 wheel? also caddy calipers are used to retain the parking brake
  12. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I know I have been searching on this site for 2 days on how I can connect my e-brake cable to Caddy calipers. I think i need some sort of arm, but GM discontinued the part so maybe I am SOL. :rolleyes: :mad:
    EDIT: Sorry found the answer ;)
  13. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    They are talking about 8 lug 14bsf's with the big drums. 15 inch wheels fit just fine on 6 lug 14bsf drums :wink1:
  14. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I think I might just disk brake my 14bsf when I get it :wink1:
  15. franco802
    Oct 16, 2004
    270
    San Diego, CA
    Only thing that scares me is, I have seen alot of threads in here with people not having any pedal after a rear disc swap:confused:
    I am still kinda having thoughts on either just leaving it with drums or doing the swap with the ebay kit.
  16. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the 14bsf have 2 different drum sizes, as does the 14bff. the smaller 11" brakes will clear no problem. the 13" brakes should clear, depending on the back spacing. i have no problem clearing either with the 2.75" backspacing on my wheels.
  17. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Ya I heard that too. I thought it was because the calipers where positioned incorectly :dunno:
  18. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    It's up to you. Personally, I chose to use the drums because they are already on the axles, they simplify e-brakes (because they are built in), and they work well (especially since they are a bit larger than 1/2 ton drums). This is probably why GM has gone back to using drums on the rear of trucks :wink1:
  19. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I was thinking that drums would eliminate A TON of guess work. And would be cheaper too. Plus my 1/2 ton brakes with rear drums do a decent job too.
    But one question is: Does anyone know for sure if the 8 lug drums and the 6 lug drums were the same size? And will interchange along with the 6 lug axel shafts I'd put in? Or rather: are the 6 lug drums the 11" or 13" or available in both sizes?
  20. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    When we were picking up my buddies' 6-lug 14bsf the other day I looked at an 8 lug axle. The drums are definitely different, but the backing plates and hardware may be the same (this is the 11" version, of course). I couldn't tell for sure, though...
