14 bff pinion nut socket size???
Discussion in 'The Garage' started by alec78, Aug 18, 2005.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Just what the title says... I need to buy one and would like to make one trip.
    Sooo... What size is the pinion nut on a 14 bff?
  2. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
  3. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Good luck finding one that has thin enough walls to fit in the pinion though. I ended up buying a cheap set of monster sockets from Harbor Freight just to get the socket that had thin enough walls to get down around the nut. My Craftsman socket was too thick. I've heard some folks actually grind down a cheap thick wall socket to fit.
  4. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Went to autozone and bought a Great Neck Brand 1-1/2" for my 14ff and a 1-5/16 for my D60, The one for my 14ff fit fine, but the one for the D60 is very tight. It worked w/o grinding, but I considered doing it because it didn't quite fit all the way into the yoke, but still got a good bite.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    S&K has larger sockets that have thin walls. Got one that fit my D60. Will probably be where I go for my 14ff if the socket I already have doesn't fit. :)
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I got my socket at sears, I dont remember the exact size, I will check when I get home but I do know that it was a 3/4" drive socket i used. The thing fit it there absolutely perfectly.
