14 BFF???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trikstark5, Sep 5, 2004.
  1. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    How many quarts of gear oil goes in a 14 bolt? Is there a specific company's gear oil that is better than someone else's?
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    About 1 gallon
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I was told just under a gallon with an aftermarket diff cover. Remember it fills the axletubes too to lubricate the shaft. I plan on using just standard 90 weight. I think that is what I have a few gallons of.
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    and if its Gov-loc...u should run some kind of limited slip additive ( I believe /forums/images/graemlins/thinking.gif)
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    According to Eatons web site the Gov loc does not need an additive. The gear oil I buy is usually limited slip posi friendly though.....can't hurt. Oh yea the 14ff takes an A$$ load of gear oil. I actually put just over a gallon in mine /forums/images/graemlins/yikes.gif
  6. trikstark5
    Feb 17, 2004
    169
    usa
    What about a Detroit locker?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nothing but gear oil required. /forums/images/graemlins/thumb.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The only time an additive is required is if there are clutches involved.
  9. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    Gov-locs dont have clutches??
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I was just making a remark as to when an additive or special gear oil is needed.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Gov locs do have clutches, and whether or not they require additive is a matter of debate. I personally don't put anything in them and I've never noticed any chatter.
  12. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    im just making sure that not running special additive's in my gov-loc wont hurt it /forums/images/graemlins/thumb.gif
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    It will, unless the worn out. As stated before if it has clutches, it needs posi additive.
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    The Gov-lock clutches aren't used like regular limited slip clutches. Remember, the Gov-lock is a locker. It is supposed to be full open or full locked. The clutches only see slip in the instant the thing is locking or unlocking.
  15. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    In a POS (gov loc) differential... It operates as follows:
    clutch packs are engaged all the time just like a limited slip, except weaked than most other limited slips. When the speed of one wheel exceeds the speed of the other by a set (way too many) number of RPMs, the stupid little weights and widgits and such cause it to lock up solid...like a spool. When the load comes off it, it goes back to limited slip operation. It should have additive in it....well actually, if you take my not so humble opinion, it should have a detroit in it.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It also stops functioning at 20 mph.
  17. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    or so they say.
