14 Blot FF - Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Aug 5, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I just ordered my 14 Bolt FF from Brians 60s....It may be a long time until I can install it but at least I have ordered it. I understand this is a direct bolt on.....BUT....do I need to do anything to the driveshaft? Or do I only need a special UJoint
    I am also going to install a 4" lift at the same time, RoughCountry. When I do all this, is there anything else that is a "must do" that will save me time and keep me from doing things twice. Thanks....any and all suggestions will the very Welcome.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I only needed the hybred u joint the Napa # is posted quite a bit on here. Everything was bolt in. On the older axles (79? back) the parking brake cables are different.
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also if it is a 1 ton axle you will need to relocate the spring perchs and shock mounts to put it under a K5.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    I thought I mentioned you would need to move the spring perches in my emails to you. If I did not, I appologize. the other thing you will need is a conversion u-joint, and ubolts with u bolt plates. everything else is minimal. I will let you know when I recieve your money. thanks, Brian
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  5. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I thought only the 1-ton duallys needed relocation while the 1-ton SRW were a bolt on
  6. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    to my knowledge, they are only bolt ins in pre 73 chevys.
